Eastern European's Infiltrate
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Other Strokers
PostPosted: Fri Feb 13, 2015 11:22 pm    Post subject: Reply with quote
Upgrade ???
Shocked Shocked Shocked
emzedder
PostPosted: Thu Mar 12, 2015 8:00 pm    Post subject: Reply with quote
Front brake upgrade kit installed on the MZ ....
If it don't ring-a-ding-ding it ain't worth a thing
PostPosted: Thu Mar 12, 2015 8:45 pm    Post subject: Reply with quote
Is this turning into the woefully inappropriate upgrades thread?
PostPosted: Thu Mar 12, 2015 8:47 pm    Post subject: Reply with quote
Or even this?
Both get my approval i like little bikes with big engines!
PostPosted: Thu Mar 12, 2015 9:46 pm    Post subject: Reply with quote
Certainly made me smile! Very Happy
emzedder
PostPosted: Fri Mar 13, 2015 6:11 pm    Post subject: Reply with quote
Get twenty miles out of a rear tyre?
PostPosted: Fri Mar 13, 2015 6:38 pm    Post subject: Reply with quote
Looks like the bottom one is actually a trike?
PostPosted: Fri Mar 13, 2015 8:02 pm    Post subject: Reply with quote
I dont think id stay on it long enough to need to worry about how long a rear tyre lasts! On the plus side i bet you never need a front tyre, it will never be on the floor!
emzedder
PostPosted: Tue Aug 04, 2015 8:09 pm    Post subject: Reply with quote
July was a bit damp, still been hooling around Norfolk, this was one of the least wet days ... August been good so far!
DSBBadmin
Site Admin
PostPosted: Wed Aug 05, 2015 8:25 am    Post subject: Reply with quote
This was for sale at Cadwell, it belongs to reverse cylinder jim on here. Lot of nice touches on it, pretty cool. Cool
emzedder
PostPosted: Fri Aug 07, 2015 7:21 pm    Post subject: Reply with quote
Nice, all the right stuff. Too smart for me .....!
ajb235
PostPosted: Wed Aug 12, 2015 4:27 pm    Post subject: ETZ250 mods Reply with quote
Hi, I,m new here, but looking at major mods to my ETZ 250' which I wanf to use on the road as a cafe racer, rather than racing.
Two big things to do
1. Reed valve : Is there a thread on this forum (or anywhere )that shows just how this is done?
2. Exhaust : I' m going to fabricate an exhaust system that will unleash the true potential of these engines.
Would appreciate any guidance, reed valve procedure is the main thing.
Thanks
emzedder
PostPosted: Thu Aug 13, 2015 5:26 pm    Post subject: Reply with quote
Things to do that make a difference that I can help you with:
1. Replace the heavy MZ piston with a Sukuki TS250 alternative ... much lighter gudgeon pin is straight fit
2. Shorten barrell top and bottom to match Suzuki piston crown and skirt lengths
3. Re port as necessary for (2)
4. Trim lots of weight off clutch ... preferably with alloy clutch outer
5. Reed valve ... can increase inlet opening time massively but need to know what you doing on porting. Use a 4 petal RD unit as that is good enough. Quite a bit of machining unfortunately
I'll send you my port map if that is helpful
ajb235
PostPosted: Thu Aug 13, 2015 9:27 pm    Post subject: ETZ250 tuning Reply with quote
Thanks for the information, some useful advice there,which I will follow. The port map would be even better, no substitute for experience!
Thank you.
emzedder
PostPosted: Fri Aug 14, 2015 6:16 pm    Post subject: Reply with quote
No problem, trick is to get some more power while not sacrificing reliability and starting (the old chesnut for strokers) my setup gives a more exciting ride but no lap records. Boring the carb by 1mm is beneficial but better to go for an appropriate Mikuni if you can afford it.
I have fitted a Kart PVL ignition which has been brilliant but is not cheap. Run slightly retarded ignition from standard to start with and slowly advance until you get a good response.
I have boost ports which make a difference but a tricky machining task ...worth the effort
Pipe is all about maths but I have a generic dimension setup if you would like that. Message me your mail address.
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Other Strokers All times are GMT
Page 5 of 6
