Clutch cable splitter
dougindoors
PostPosted: Sun Jun 05, 2016 3:14 pm    Post subject: Clutch cable splitter Reply with quote
Has any one else got a cable splitter on the clutch cable it's located on the left hand side mounted to the frame just under the tank, the unused cable comes out the back of the tank under the seat, has me fooled.
Two Smokey and they bandit
PostPosted: Sun Jun 05, 2016 6:47 pm    Post subject: Reply with quote
The spare cable from the splitter is for the side stand.
The early versions also had a switch on the side stand too. This was removed on the later versions B3 onwards but the cable was retained.
Aka: When you pull the clutch the side stand lifts itself into the safe riding position.
dougindoors
PostPosted: Sun Jun 05, 2016 8:06 pm    Post subject: Splitter Reply with quote
Ah ha, I did suspect that, it was the only thing I could think it did, unless it controller the ejector seat for the pillion lol. By the way Shaun the left side panel has all its lugs so I have a patern, but thanks for your time and the photos.
Powered by phpBB © 2001, 2005 phpBB Group.  Installed, administered and modified by  Diff'rent Strokers © 2006-2018.
