Kawasaki AR125 Stainless Steel Laser cut radiator grill
PostPosted: Sat Jun 03, 2017 11:14 pm    Post subject: Kawasaki AR125 Stainless Steel Laser cut radiator grill Reply with quote
Had some Stainless Laser Cut Radiator Covers made as a direct replacement to the rusty steel BBQ grill kindly provided by KHI
Will not be to everyone's taste, but at least its nice to have a few blingy extras that normally only seem to be available to Yammie owners..
As fitted to Decs bike today..
andyw114
PostPosted: Sun Jun 04, 2017 4:40 pm    Post subject: Reply with quote
That looks very nice. Did they charge much for a one off?
PostPosted: Sun Jun 04, 2017 7:46 pm    Post subject: Reply with quote
Had it made in Thailand.. the first one to make a pattern was not that expensive.. the next 9 were then an absolute bargain Smile
Order of 10 was really the minimum to make it worth their while..as far as I was concerned it was a steal. Not making loads for EBay.. .it's to my design and only for dedicated AR fans Smile
I'm quite pleased with the results and fit spot on Cool
PostPosted: Mon Jun 05, 2017 3:01 pm    Post subject: Reply with quote
Love it, love the use of the old Kawasaki symbol thingy/emblem?
I would buy one of these, if I had an AR125.
Top work TS
PostPosted: Mon Jun 05, 2017 5:50 pm    Post subject: Reply with quote
Top work TS
Thanks Howie
The symbol is the KHI (Kawasaki Heavy industries) logo that was ressurected on the new supercharged bike. Just thought it was credible like the Yamaha logo.
If you had a wonderful AR125 Mr H it would be a pleasure to let you have one... you know you want to Taunt Giggity Very Happy
andyw114
PostPosted: Mon Jun 05, 2017 8:19 pm    Post subject: Reply with quote
Looks like they did a good job.
PostPosted: Mon Jun 05, 2017 8:55 pm    Post subject: Reply with quote
Thanks Andy
They certainly did. It's way better in the flesh than the photos show.
Good to know this kind of thing can be made fairly easily.
I've had gasket sets, clutch damper kits, brake fittings and rare inlet rubbers made up to now. But this is the most impressive part to date Smile
PostPosted: Wed Jun 07, 2017 7:51 am    Post subject: Reply with quote
Top-shaggy wrote:
...gasket sets, clutch damper kits, brake fittings and rare inlet rubbers made up to now.
Ooh, clutch damper kits...just the thing I wanted for my SDR. Can you confirm that the material used was/is suitable? If so, can you point me/us in the direction of your supplier Shaun?
Thanks & regards,
PostPosted: Mon Sep 04, 2017 11:33 am    Post subject: Reply with quote
Thanks & regards,
Hi James
Does this work for your SDR?
http://m.ebay.com/itm/Yamaha-DT125-DT125MX-Damper-Clutch-Kit-Repair-NEW-2N4-16000-00-/262501678343?epid=1675236098&hash=item3d1e51bd07%3Ag%3APIsAAOSwgY9XcnRy&_trkparms=pageci%253Ab6092a29-90df-11e7-896e-74dbd180f678%257Cparentrq%253A4942026e15e0a7f2279b23f9fffb6811%257Ciid%253A16
PostPosted: Sat Sep 09, 2017 2:54 am    Post subject: Reply with quote
Top-shaggy wrote:
Thanks & regards,
Hi James
Thanks for that Shaun, but those DT125 dampers look quite different. It may be possible to cut the kidney-shaped pieces in half and remove the connecting webs, but I'm not even sure if they will be the correct size Sad .
Still, thanks for the info!
Powered by phpBB © 2001, 2005 phpBB Group.  Installed, administered and modified by  Diff'rent Strokers © 2006-2018.
