rg250 mk 3 Rear Shocker
wolfman
PostPosted: Mon Feb 07, 2011 1:13 pm    Post subject: rg250 mk 3 Rear Shocker Reply with quote
hi all
Does anyone know if you can dismantle the rear shocker so i can get the spring powdercoated, and if so how bad a job is it.
cheers charlie.
Riding a two stroke is sometimes like buying a one way ticket!!!!!
Crofty
PostPosted: Mon Feb 07, 2011 7:55 pm    Post subject: Reply with quote
I enquired about getting mine done, and was told no, it cant. Sad
I cant see how the rusty looking ring would come off, if the spring was compressed....tho I do have a home made spring compressor at work, I'll have a look and let you know.
Breathing new life into an old Gamma!
http://www.rg250.co.uk
trev45
PostPosted: Mon Feb 07, 2011 8:21 pm    Post subject: Reply with quote
If man put it together he can pull it apart Wink
Trev
Racing is for the track, riding is for the road
Both are FUN
RGRobby
PostPosted: Tue Feb 08, 2011 10:12 pm    Post subject: Reply with quote
Hi Charlie,
You could try Brook Racing in Bradford (01274 414768) who told me he can rebuild the rear shock for an RG250 but said it would be expensive compared to buying a new aftermarket shock - could be worth a phone call though? Confused
I'm trying to find someone to make the exhaust can shrouds for my bike, did you have any joy with getting yours re-made?
Cheers, Rob.
PostPosted: Wed Feb 09, 2011 7:50 am    Post subject: Reply with quote
On most other bikes there's a slot in the side of the spring seat so that with the spring compressed it just comes out over the damper rod.
Can't you compress the spring, cut off the existing spring seat, and then use one from something else to put it back together?
