Help!!!!
boney
PostPosted: Fri Aug 05, 2011 8:51 pm    Post subject: Help!!!! Reply with quote
My 125lc won't start!!! Went out yesterday and ran fine, came home got changed and wouldn't start! Got no live at coil with ignition on or when it's kicked! Any ideas anyone????
bobbyboy
PostPosted: Sat Aug 06, 2011 11:06 am    Post subject: Reply with quote
Start with the obvious first, check the killswitch!
If it ran fine before you stopped, you may have hit it by mistake.
You wouldn't be the first to overlook this, even experienced riders do.
www.taffmoto.co.uk for your replacement fairing panels
boney
PostPosted: Sat Aug 06, 2011 2:45 pm    Post subject: Reply with quote
Cheers mate, the kill switch on mine has been disabled and has never worked!!!
bobbyboy
PostPosted: Sat Aug 06, 2011 3:15 pm    Post subject: Reply with quote
So is it up and running now?
If not, is the ignition switch working correctly, with the idiot lights showing?
Main fuse still intact?
How did you check the coil output?
boney
PostPosted: Sun Aug 07, 2011 12:28 pm    Post subject: Reply with quote
Not running yet, ignition switch working as it should. Tested the live to the coil with ignition on and when kicked over. Also tested coil feed at cdi and nothing there either.
boney
PostPosted: Wed Sep 28, 2011 10:06 am    Post subject: Reply with quote
Been having problems with my RD125lc not starting. I have got power to the coil when kicked over but no spark.
I have tried a brand new coil, different cdi, different stator coil and flywheel, dissconnected ignition switch and cutt-off switch and tested all wires between stator and cdi but still no spark????
I'm going to try thrashing it with a hammer next!!!!!
Read more: http://www.rdnuts.proboards.com/index.cgi?board=advicehelppage&action=display&thread=818#ixzz1ZExfWuV5
PostPosted: Wed Sep 28, 2011 10:15 am    Post subject: Reply with quote
New plug ?
PostPosted: Wed Sep 28, 2011 1:09 pm    Post subject: Reply with quote
Squirt some fuel in the air fiter and then try to start it. Try to narow it down to electrics or fuel. All it needs to run is compression, fuel and a spark.
boney
PostPosted: Thu Sep 29, 2011 9:34 am    Post subject: Reply with quote
Have tried 2 plugs and it is getting fuel but no spark to burn it.
Malc
PostPosted: Thu Sep 29, 2011 5:55 pm    Post subject: Reply with quote
Check low tension wiring - was an issue 20 years ago on LCs so gotta be worth a look?
boney
PostPosted: Sat Oct 01, 2011 8:33 pm    Post subject: Reply with quote
If i take the wire off the coil and test it, it has power when the bike is kicked over. When connected back to the coil and then tested there is no power running through it!!!!!!!!!!
