AR125 info on steering head bearings
PostPosted: Sat Dec 29, 2012 1:16 pm    Post subject: AR125 info on steering head bearings Reply with quote
In responding to another post, I thought I would show the difference between top / bottom steering head bearings on the AR125 - OEM compared to aftermarket roller bearings.
The ones to the left are for the top of the steering stem and have an inner diameter of 25mm
The ones to the right are for the bottom and have an internal diameter of 28mm
Both sets (upper and lower) have an external diameter of 46.02mm (measured cold 10 degrees C)
Ball bearings for OEM cones not shown.
Very Happy
PostPosted: Sat Dec 29, 2012 7:09 pm    Post subject: Reply with quote
Hello again ts do you know the actual ball bearing diameter? Or am i just being far too picky now! They were pretty new races when i stripped it so really just want to replace the balls but i wanted to order them from a local bearing suplier rather than ebay,
If not ill just have to replace with rollers
PostPosted: Sat Dec 29, 2012 9:17 pm    Post subject: Reply with quote
Ball bearing diameter is: 3/16 inch or 4.7625mm
I went to the garage to measure them and realised the size was in the parts scan above... Rolling Eyes Wink
PostPosted: Sun Dec 30, 2012 11:12 am    Post subject: Reply with quote
Thanks again, i should have zoomed in a read that really so sorry to have wasted your time!
PostPosted: Sun Dec 30, 2012 12:58 pm    Post subject: Reply with quote
Yeah, fancy wasting my time ...ho ho ho
Not a problem fella, I'm more that happy to help Thumbs Up
PS you can owe me a pint when I catch you at the Premier Wink
