ar 125 rebuild and mod
Goto page 1, 2, 3 ... 13, 14, 15  Next
PostPosted: Tue Sep 08, 2015 10:15 am    Post subject: ar 125 rebuild and mod Reply with quote
the purists of this site aint going to like what I'm doing but i fancy doing something different so here we go.
going to try and still keep the standard-ish looks. it will evolve has it gets put back together.
has it is now. for future reference.
[img
rubbish with electrics may need some help.
[/img
easy bit taking apart.
[img[/img]
PostPosted: Tue Sep 08, 2015 10:29 am    Post subject: Reply with quote
carb rubber looks pretty shagged anyone know were i can get another.
[img
[/img]
PostPosted: Tue Sep 08, 2015 10:45 am    Post subject: Reply with quote
Got my hands on this today.
[img
And this 5 mm aluminium plate to make new footrest hangers.
[/img
PostPosted: Tue Sep 08, 2015 10:58 am    Post subject: Reply with quote
I like to see things being "improved", keep us posted!
PostPosted: Tue Sep 08, 2015 12:30 pm    Post subject: Reply with quote
Great Stuff!!
Get stuck in, forget purists. . it's not called Diff'rent Stroker for nothing Smile
Check out ebay.com for carb rubber but they proper rare as a rare rare thing.. if you can't find one then I will help sort you one out from my stash.. It will give me an excuse to pop up and meet you on one of mine Smile
PostPosted: Tue Sep 08, 2015 1:20 pm    Post subject: Reply with quote
who would you trust locally to rebuild the engine ?
frame goes in next week for powder coating and a few other bits.
wheels will be done by myself, want to keep the polished rims. (seems no one wants to take this job on)
tank and panels in one colour, best price i have had is 700 OUCH!
anyone know if its possible to fit an electric speedo and rev counter to the ar ?
AR-jack
PostPosted: Tue Sep 08, 2015 8:33 pm    Post subject: Reply with quote
just as some help make sure to treat the nikkon pipe before using it got one from last year and it was not painted or chromed or even anything and its just went to rust but are a hell of an exhaust nice sound beefy sound to them and better when running a tuned engine XD
AR-jack
looking very good! hope to see it when it is finished!
PostPosted: Fri Sep 11, 2015 9:03 pm    Post subject: Reply with quote
fazey wrote:
shaun you don't need an excuse to pop over your welcome anytime.
Hi Pete,
Found a new rubber inlet for you and sent a PM regarding engine rebuild.
I've seen quite a few AR50/80s with electronic speedo and rev counters but not a 125. I would presume its the same fitment.
I'm likely to be at Cadwell on Sunday for Derby Phoenix racing, let me know if your there and I will take the rubber inlet with me.
TS
PostPosted: Sat Sep 19, 2015 3:47 pm    Post subject: Reply with quote
thanks for that info jack.
guy who sold it me says it has 2 coats of clear lacquer applied.
thanks shaun your a star.
well grinder out. no turning back now. started by taking the centre stand brackets off then the indicator brackets the helmet lock was ground off. most of the weld splatter ground back and all the raised weld.
onto the swingarm. chain guard brackets ground off has was the shock guard brackets. a little more prep and its off to the coaters.
wheels have been sent off to be polished and painted.
trying to source all new stainless bolts and nuts at the minute.
[img
a few bling bits added.
[/img
getting prepped.
[img
[/img]
PostPosted: Sat Sep 19, 2015 3:52 pm    Post subject: Reply with quote
Wow, action shots!
Don't get many of them on here.
Keep up the good work and the photos.
PostPosted: Sat Sep 19, 2015 8:50 pm    Post subject: Reply with quote
Brilliant stuff Pete !
AR-jack
PostPosted: Sun Sep 20, 2015 1:01 pm    Post subject: Reply with quote
looking good!!
PostPosted: Sun Sep 20, 2015 7:58 pm    Post subject: Reply with quote
fazey wrote:
Thumbs Up
PostPosted: Mon Sep 21, 2015 8:50 pm    Post subject: Reply with quote
Uselessinformation alert.....
Seeing that pic reminded me of college when we had to learn about diffrent metals, did you all know that when you grind them they have diffrent spark patterns? Thats pics a very good example is all!
Page 1 of 15
