kdx rear wheel advice
GRAVEL TRAP EXPLORER
PostPosted: Sun Oct 04, 2015 8:08 am    Post subject: kdx rear wheel advice Reply with quote
So the normal evil bay search for a rear wheel on the kdx is proving fruitless . I dont want to buy new as im trying to keep costs down as she needs so much other bits replacing. Any suggestions on what would fit from other models guys ?
i ve got it ive gt it ive got it sky grass sky grass sky grass ambulance.
PostPosted: Sun Oct 04, 2015 9:07 am    Post subject: Reply with quote
Is the KDX wheel different from the KMX?
Rear KMX wheels also differ in size between 125 and 200 models.
If you post a picture and sone dimensions maybe we will be able to help?
PostPosted: Sun Oct 04, 2015 7:11 pm    Post subject: Reply with quote
Its an 18 inch tyre the rim is in such a state I can not find any thing stamped on it .
PostPosted: Sun Oct 04, 2015 11:58 pm    Post subject: Reply with quote
120/90 x 18 tyre is fitted to KMX125 model rear wheel (4.1 x 18 )
May be worth checking out this as an alternative ?
PostPosted: Mon Oct 05, 2015 8:25 am    Post subject: Reply with quote
Having checked one of my 'all things Kawasaki' books, the rear wheels on the KMX125 & KDX125 are the same size, however disc size is different (Kmx is 230mm Kdx is 220mm) & disc bolt spacing is different, so you can't just swap discs.
TS is right about larger rim sizes on the bigger models. I'll have another look later but maybe look at the Kx range???
Also it looks like none of the 4 strokes share the Kdx's rear wheel.
PostPosted: Mon Oct 05, 2015 3:11 pm    Post subject: Reply with quote
Gentlemen thank you thats a great help . ill see if i can source a kmx wheel and disc or rebuild using kdx hub and kmx rim. Thankyou once again.
PostPosted: Mon Oct 05, 2015 3:51 pm    Post subject: Reply with quote
Pic does not show the two and a half inch hole filled with body filler in the rim . Love a learner bike!
