1988 ar125 b2 rebuild :) very photo heavy
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Nov 11, 2015 11:22 pm    Post subject: Reply with quote
AR-jack wrote:
even on the A1 its very very close i had to adjust the brake rod so it would not touch lol
Sounds to me like the jig used for the new nikkons needs adjustment.. Their is no need for the Silencer to be too close to the swingarm. Plenty of room.
PostPosted: Wed Nov 11, 2015 11:27 pm    Post subject: Reply with quote
AR-jack wrote:
also on the old points bikes the frame does not have cdi or reg mountings fitted
and the crank uses a pin instead of a woodruff key
and some harnesses are alittle different due the the removal of the side stand switch on the later models
you can convert the points harness to a cdi using a sub harness
please correct me if im wrong?
Your not wrong.. Lots of differences..
Ever noticed the whole crank is different ?
The conrod size is different?
The flywheel is different?
The early pistons are different......?
Some parts can switch models, some can't ..
Got to be careful now.. Or I will sound like a Michael Caine parody ... Haha
AR-jack
PostPosted: Wed Nov 11, 2015 11:41 pm    Post subject: Reply with quote
yeah i read about the older pistons have 1 bar in under the dome while the later have 3 and yeah the flywheel of cause lol due to the ignition been points instead of cdi and the cover is different
did not know about the conrod or the rest of the crank
sounds abit like the early td27
with the nikkon its the chamber that hits but ive got no problems with it as it is now
XD
jack
PostPosted: Thu Nov 12, 2015 12:24 am    Post subject: Reply with quote
Yeah .. Watch out for the con rod.. Same stroke but early models only 14mm wide and later 18mm wide Smile
Here's a more unusual one ...? Why is the plate across frame under battery box different between models too?
AR-jack
PostPosted: Thu Nov 12, 2015 12:35 am    Post subject: Reply with quote
i kinda sounds like it may use a kh conrod? they are thin (also use the same piston)
yes i noticed that on both A models
ive also noticed in heavy rain there is spray getting around the intake of the air box i also found after over a week straight of heavy rain the airbox began to get alittle damp (did not affect the bike but somthing to note)
but on the later models there is like a splash plate added believed to stop this
also notice on the later models the swing arm mounts are double plated
and on early models the center stand feet are small while the later are large and wrap around
XD
jack
PostPosted: Thu Nov 12, 2015 12:42 am    Post subject: Reply with quote
That's why the airbox has a 'wall' of plastic before the rubber opening to the shock.. To stop water getting back into the filter...
Look out for some tuned ARs as this 'wall' is reduced / cut away inside the airbox Smile
PostPosted: Thu Nov 12, 2015 12:51 am    Post subject: Reply with quote
Front engine mounts are different on B2/A3 model and very hard to find..
Rear Torque rod is flat pressed steel on early models too..
Oh dear.....
I'm sure you set me off on purpose.. And I've fell for it ..haha
AR-jack
PostPosted: Thu Nov 12, 2015 12:59 am    Post subject: Reply with quote
yep
lol we both can go all night haha
XD
jack
AR-jack
PostPosted: Thu Nov 12, 2015 1:10 am    Post subject: Reply with quote
when it comes for somthing i can go for a while lol XD
the ar is one
XD
jack
AR-jack
PostPosted: Mon Dec 21, 2015 5:03 pm    Post subject: Reply with quote
gob back around to the ARs
smoothed the tank down (some scum before i got it hit the bike with a hammer)
first coat of primer i may tomorrow sand down and possibly another coat Smile
XD
jack
AR-jack
PostPosted: Mon Dec 21, 2015 5:04 pm    Post subject: Reply with quote
ive only put them back on the bike as its dried also its kinda one of the safest place to put them lol
XD
jack
PostPosted: Mon Dec 21, 2015 7:42 pm    Post subject: Reply with quote
You must have s nice warm workshop ?
Every time I do any painting it blossoms in this weather.... Grrrrrr Smile
AR-jack
PostPosted: Mon Dec 21, 2015 8:27 pm    Post subject: Reply with quote
its not very warm lol
the boiler house isnt much either but warn enough (i really miss the old muti fuel boiler we had could have the room 30 deg easy lol)
so the silver may have to wait for a while :/
XD
jack
AR-jack
PostPosted: Mon Dec 21, 2015 8:29 pm    Post subject: Reply with quote
adleast its kinda dry for once
XD
jack
AR-jack
PostPosted: Tue Dec 22, 2015 9:30 pm    Post subject: Reply with quote
never got around to putting another coat on but did manage to smooth down ( i ended up spend afew hours sorting a honda lead out for a lad it was a annoying lol)
she is tho looking more like a bike again :3
XD
jack
Page 3 of 6
