Kawasaki AR125 Cable Routing
Sean
PostPosted: Wed Jul 05, 2017 3:14 pm    Post subject: Kawasaki AR125 Cable Routing Reply with quote
Finally got the engine back from BDK, just having a few fun and games with cable routing.
I don't suppose anybody has a few pictures of the correct paths in and around the frame
Sean
PostPosted: Wed Jul 05, 2017 7:16 pm    Post subject: Reply with quote
Yes but I can't post them until PhotoFooket sort themselves out
If your on FB look me up and I will send you the pictures you need ok
Shaun
Just look for AR125 owners and White AR80 and 125 Wink
Sean
PostPosted: Sat Jul 08, 2017 7:36 pm    Post subject: Reply with quote
Thanks for making contact
Just having a few issues with the throatle cable routing, it seems to big
BDK did all the work we spoke about, the only other part that needs re thinking is the carb
I have sent a message on FB did you get it
Sean
PostPosted: Sat Jul 08, 2017 11:20 pm    Post subject: Reply with quote
Hi Sean
Check your Messenger ..you should have a couple of response messages waiting for you penting acceptance.. happy to help.
If that doesn't work then I will send you a friend request and you can check out my photo folders etc
Best
Shaun
