aDTisbornagain
Posted: Thu Nov 06, 2014 6:58 pm Post subject: dt 125 lc mk 1 wiring |
| does anyone know what I would need to basic run the bike , I have a cdi / a coil / ignition switch / rectifier/ indicator relay , no regulator , the battery is 6 volt is it possible to run it with just a few wires forgetting about lights etc???? any hints would be welcomed |
Posted: Thu Nov 06, 2014 10:28 pm Post subject: |
Iv got a fairly butchered loom sitting in my basement, might be usefull for parts or i can try and get some photos, might even be a reg attached to it still, it was from a ysr that had a dt engine and i think it was 6 volts, ill have a look when i can and try and get some pics up of some components to see if anything matches _________________ Gagging for it |
aDTisbornagain
Posted: Fri Nov 07, 2014 12:33 am Post subject: |
| Gillinghampaul wrote: |
| Iv got a fairly butchered loom sitting in my basement, might be usefull for parts or i can try and get some photos, might even be a reg attached to it still, it was from a ysr that had a dt engine and i think it was 6 volts, ill have a look when i can and try and get some pics up of some components to see if anything matches |
cheers tht would be great if u could |
aDTisbornagain
Posted: Fri Nov 07, 2014 1:52 am Post subject: |
| aDTisbornagain wrote: |
would this work the bike this basic circuit |
Posted: Mon Nov 10, 2014 1:12 pm Post subject: |
| it should work! you won't need the wire from the battery to the ignition switch though as it should power the cdi from the pick up coil on the engine. You have wired the engine kill wire in (black/white) this will be required should you need to stop the engine if you can't stall it |
