Posted: Mon Oct 05, 2015 11:17 am Post subject: Kawasaki AR125 horn problems! |
Hi Guys n Gals,
when I bought my AR125, it didn't have a horn, or the bracket to mount. I soon sourced replacements and fitted them yesterday but found that no sound came from it.
I checked the norn, by putting 12v across the terminals and it worked fine.
I dismantled the switch and checked the resistance, when the button was depressed and that worked fine, so it would appear there's a problem in the wiring itself.
When I next have a day off, I'll take a good look but I wonder if anyone else has had similar problems, which may speed up my progress? _________________ Kindest regards
Posted: Wed Oct 07, 2015 8:41 pm Post subject: |
Hi Guys n Gals,
wel I stripped down the lefthand switch gear, put everything back again and would you believe it, the bloody thing burst into life!
So while on a bit of a roll, I decided to see if the replacing of the exhaust gasket would result in a proper seal being made and, would you believe it, it did!
I cranked her up and she soon ran to a very steady idle, which made my day.
Next I found that the brake light worked, as did the instrument lights, headlamp dipped and main beams but not the tail light. So I guessed that one of the tail light bulb filaments had failed. However, when I went to put the bike back into the garage, I turned the ignition key one detent too far, to find the parking lights came on! WTF?
So it looks like more electrical tweaking will be required tomorrow. _________________ Kindest regards
Posted: Wed Oct 07, 2015 10:36 pm Post subject: |
The Cameraman wrote: |
Erm... Yep..
That's what it's supposed to do _________________ We are where we are... |
Posted: Thu Oct 08, 2015 1:58 am Post subject: |
Hi Shaun,
I know it is matey but why wouldn't the tail light show when the lights were switched on but worked when set to park, if you see what I mean? _________________ Kindest regards
Posted: Thu Oct 08, 2015 6:36 am Post subject: |
Hi Shaun,
I know it is matey but why wouldn't the tail light show when the lights were switched on but worked when set to park, if you see what I mean? |
Aaah.. Getcha ..
Hope you suss it out soon mate. i would work my way back from tail light to switch with me test gizmo _________________ We are where we are... |
Posted: Thu Oct 08, 2015 8:42 am Post subject: |
Top-shaggy wrote: |
Hi Shaun,
Aaah.. Getcha ..
Hope you suss it out soon mate. i would work my way back from tail light to switch with me test gizmo |
Hi Shaun,
just heading outside to give it a go!
Fingers are crossed. _________________ Kindest regards
Posted: Mon Oct 12, 2015 5:12 pm Post subject: |
Hi Guys n Gals,
I disconnected the wiring harness, clicked it back again, and it all came back to life! _________________ Kindest regards
Posted: Mon Oct 12, 2015 10:51 pm Post subject: |
Hi Guys n Gals,
I disconnected the wiring harness, clicked it back again, and it all came back to life! |
Sounds like just dry terminals and very slight oxidation of the connectors .. Gad you sorted it out _________________ We are where we are... |
Posted: Tue Oct 13, 2015 5:11 am Post subject: |
Top-shaggy wrote: |
Hi Guys n Gals,
Sounds like just dry terminals and very slight oxidation of the connectors .. Gad you sorted it out |
Hi Shaun,
my thoughts exactly!
Either that, or a break in the harness, when I moved it. Fingers crossed it's the former and not the latter!
Just awaiting for a delivery of a certain product that you recommended, before I go to the next stage of the build.
Looking forward to Saturday. _________________ Kindest regards
