AR125 rotary disk valve
PostPosted: Sat Nov 10, 2012 6:38 pm    Post subject: AR125 rotary disk valve Reply with quote
I have been asked what is the difference between the Disk valve profile for 'A' model (unrestricted 21bhp) and 'B' model (restricted 12bhp) kawasaki AR125
See picture below:
Both disks are NLA from KHI in the UK
You can cut the B model disk to change the valve timing to match the unrestricted A model using this profile
TheNewGuy
PostPosted: Mon Nov 12, 2012 9:14 pm    Post subject: Reply with quote
how can i check if my bike is unrestricted?.. yes it has a swapped barrel but if the valve is different it would still be slightly restricted?
Shocked
Current bikes
ar125
fj1200
TheNewGuy
PostPosted: Mon Nov 12, 2012 9:17 pm    Post subject: Reply with quote
Picture saved.. just in case i need to do some machining. Laughing
Current bikes
ar125
fj1200
PostPosted: Mon Nov 12, 2012 9:37 pm    Post subject: Reply with quote
Shocked
The A model barrel exhaust port is 27mm from top of barrel (restricted B model 29mm). Transfers no difference.
The A model head has a volume of 13-14ml (B model 15-16ml)
Cool
ar125josh
PostPosted: Thu Aug 29, 2013 7:02 am    Post subject: Reply with quote
Would you still time it up using the arrow and mark on crank ?
PostPosted: Thu Aug 29, 2013 8:44 am    Post subject: Reply with quote
Yes cut the B disk and then fit lining up arrow and mark on crank - unless you have significantly tuned it up and then cutting the disk / moving it a tooth on the splines needs to suit the port timing and exhaust.
ar125josh
PostPosted: Thu Aug 29, 2013 2:12 pm    Post subject: Reply with quote
Thanks, Im not planning on a major tuning just the disk valve, unrestricted head and just polishing the ports. Although I may pay someone else to do this as I have no experience of it and dont want to ruin the barrel.
PostPosted: Thu Aug 29, 2013 4:22 pm    Post subject: Reply with quote
You could try Mick Abbey in Harrogate, he is excellent with the barrel and head work and not too expensive. Then maybe wait for Kenny on here to work his magic with a full power spannie Smile
(c'mon Kenny pull yer finger out, haha) Wink
PostPosted: Mon Jan 26, 2015 8:59 pm    Post subject: Reply with quote
Not very often AR125 Rotary Disk Valves come up for sale...
Wow and the price is only going one way..
http://www.ebay.com/itm/NOS-Genuine-OEM-Kawasaki-AR-125-AR125-Rotary-Disk-Valve-12001-1063-Japan-/171657988603?pt=Motorcycles_Parts_Accessories&hash=item27f79d09fb&vxp=mtr
ar125josh
PostPosted: Mon Jun 08, 2015 4:19 am    Post subject: Reply with quote
Just found another as well http://m.ebay.com/itm/171818418033?_trkparms=aid%253D222007%2526algo%253DSIC.MBE%2526ao%253D1%2526asc%253D31354%2526meid%253Dd6a6eb2544724eff8b0210969330fc91%2526pid%253D100408%2526rk%253D1%2526rkt%253D25%2526sd%253D171657988603&_trksid=p2056116.c100408.m2460
fazey
PostPosted: Mon Nov 23, 2015 9:01 pm    Post subject: Reply with quote
how the hell do you shape the disc valve, it looks as brittle as rock ?
PostPosted: Tue Nov 24, 2015 12:17 am    Post subject: Reply with quote
Sounds a bit caveman.. But it can be done with good quality tin snips and then shaped / sharp edges sorted with a file. Be careful to Keep dsk as flat as possible.
Alternatively ...
This is the cheapest I've seen for ages ..
http://www.ebay.com/itm/KAWASAKI-AR125-ROTORY-VALVE-NOS-JAPAN-12001-1063-/171900419558?hash=item2806103de6:g:uUgAAOSwLVZV1aNa&vxp=mtr
If you get stuck, drop me a line and I will try to help ok
