gagster55 Show Star !
Joined: 04 Dec 2006 Posts: 219 Location: West Yorkshire
Posted: Sun Dec 13, 2015 4:15 pm Post subject: XR11/73 |
squeezing a quart into a pint pot.........
or a GT750 motor into a GSX-R400 GK73A frame.
They said it couldn't be done...........  |
Posted: Sun Dec 13, 2015 5:29 pm Post subject: |
Monster !!
I've seen a fantastic KH750 engine in a ZXR400 frame so should be ace, of course you need radiator too so tight squeeze indeed  _________________ We are where we are... |
Posted: Sun Dec 13, 2015 6:26 pm Post subject: |
| a 750 Kawasaki triple is a lot shorter than a GT750 motor - honest ! |
charlieuk
Posted: Tue Dec 15, 2015 8:25 pm Post subject: |
| Top-shaggy wrote: |
Monster !!
I've seen a fantastic KH750 engine in a ZXR400 frame so should be ace, of course you need radiator too so tight squeeze indeed  |
this one? Have to admit I love it, so will be interested to see how this one turns out
http://www.zweitakte.de/projekte/ralf_zxr/zxr_h2.htm |
Posted: Wed Dec 16, 2015 12:47 pm Post subject: |
not seen that one before - thanks for the link
I was toying with the idea of putting my spare GT750 motor into a H2 Kawasaki frame and making a proper triple (ooerrr) but having viewed a suitable donor frame on Monday, it's never going to happen.
So I'm on the lookout for another recipient............  |
Posted: Wed Dec 16, 2015 12:53 pm Post subject: |
the top radiator.............
another fits across the frame, under the headstock. |
nick69 Show Star !
Joined: 18 Jan 2007 Posts: 108 Location: Pontefract West Yorks
Posted: Fri Dec 18, 2015 2:46 am Post subject: |
| Excellent mate,looks like a neat solution |
eyrey1
Posted: Fri Dec 18, 2015 3:24 am Post subject: |
| my yz125 had a rad there when i was a lad i think it was 82 or 81 model if i remember right |
Posted: Sun Feb 14, 2016 5:08 pm Post subject: |
making the front engine mounting............
firstly, the cylinder head plate. I Araldited an oversized piece of aluminium sheet to a spare cylinder head so it wouldn't move around whilst marking it out and drilling it........
the head plate mounting bolts are 8mm, whereas the holes for the cylinder head mounting sleeve bolts are 13mm. To get the holes as accurate as possible, I cut an old sleeve bolt down........
and used it to centre the 8.5mm drill bit thus...........
so that after a visit to the pillar drill...........
and a little bit of shaping (to clear the thermostat housing).....
I ended up with this...........
some welding next.............. |
