AR-jack
Posted: Mon Apr 25, 2016 3:33 pm Post subject: |
What piston did you use?
How's the pump set up
May want to take the exhaust off and check the piston through the exhaust
And temp and fuel _________________ ar125 a1 1983, ar125 b2 1988, ar125 b4 1988, ar125 b7 1991, kinroad xt50q 2011
XD
jack |
fazey Show Star !
Posted: Mon Apr 25, 2016 4:32 pm Post subject: |
the piston and rings are oem brand new the barrel was honed.
pump isn't set up, running premix. 40-1
i did put in premium fuel for what it costs.
temp was ok just above half way on dial.
was about 9000 revs when seized |
AR-jack
Posted: Tue Apr 26, 2016 8:40 pm Post subject: |
how many miles has it done since the rebuild?
just wondering as i almost seized a kh125 after 10 miles after a new piston/rings
jetting, plug ect..
any anomalys l
also take the exhaust off and you can inspect the piston and how oily is the combustion chamber and exhaust
also going to sound dumb here but fuel starvation if its running premixed cause somthing like that? _________________ ar125 a1 1983, ar125 b2 1988, ar125 b4 1988, ar125 b7 1991, kinroad xt50q 2011
XD
jack |
Posted: Tue Jun 28, 2016 7:24 am Post subject: |
Hi Fazey,
do you mind me asking where did you get the headlamp from, as I reckon it really suits the bike and I like the clean lines created by the lack of the nose fairing?
Also, are the clocks standard or from a different bike, as the look quite different from those fitted to mine?
Congratulations on your award at CMC. _________________ Kindest regards
fazey Show Star !
Posted: Wed Jun 29, 2016 10:47 am Post subject: |
Hi reggie
The headlight is off eBay. There is loads on there. You need a 7 inch one to match the fork width. You will also need to buy the headlight brackets. Don't buy them to short you will struggle with the wiring.
The clocks are standard they are the earlier model clocks. Hope this helps.
Thanks for the nice comments. |
Posted: Wed Jun 29, 2016 6:02 pm Post subject: |
Hi Fazey,
thanks matey. _________________ Kindest regards
Posted: Fri Jul 08, 2016 6:35 pm Post subject: |
| fazey wrote: |
Hi reggie
Hi Fazey,
do you have an E-bay link for the supplier of the headlamp and (more importantly) the headlamp brackets?
Regards
Reggie _________________ Kindest regards
Posted: Sun Jul 24, 2016 12:21 pm Post subject: |
Hi Fazey,
thanks for the PM, orders have been placed. _________________ Kindest regards
fazey Show Star !
Posted: Sun Sep 25, 2016 10:54 am Post subject: |
notice the difference
Posted: Sun Sep 25, 2016 6:18 pm Post subject: |
Stunning mate  _________________ We are where we are... |
Posted: Mon Sep 26, 2016 6:28 pm Post subject: |
Bling _________________ Kindest regards
fazey Show Star !
Posted: Fri Dec 09, 2016 12:17 pm Post subject: |
Bollox, dont know how this happened.
Wonder if it was the heat in the house.
Hope someone can sort it out, dont really want to have the whole bike resprayed.
Posted: Fri Dec 09, 2016 8:28 pm Post subject: |
Oh that's really not good..unlucky!
I've got one of mine next to a radiator and has been like that more than a year and thankfully it's not attracted that same problem.
Looks unusual too like the shape of a round sticker or something that was on the tank before sprayed? Glue residue reacting under the paint? I'm sure a paint expert on here will know better than me what the cause is...
Boooooooo _________________ We are where we are... |
Posted: Mon Dec 12, 2016 2:52 pm Post subject: |
| Has it got any filler in that area Fazey? |
fazey Show Star !
Posted: Mon Dec 12, 2016 9:21 pm Post subject: |
His Howie. No idea because the tank was like that when bought.
But I suspect it may have now. |
