Posted: Wed Dec 07, 2016 3:01 pm Post subject: Kc100.......again. |
| Quote: |
Nostalgia is wonderful but I am never ever buying another bike I owned when I was younger, you move on, you buy bigger more powerful bikes, it is the way of things & there is a very good reason for it.
Ok, I may have lied a little bit when I wrote the above quote because.....
[img] [/img]
However, this is my first bike, the actual one! Looks a bit different to when I sold it.
Long story short, I sold this to my brother for his lads, I had assumed he had sold it on but he had kept it
And now it's back with me
Another pic.
9599 miles, it's barely run in
So, looks like the 80mph project may be back on!
Can't really get bored & sell this one, can I? |
Posted: Wed Dec 07, 2016 6:12 pm Post subject: |
Hi Howie,
good on ya. _________________ Kindest regards
Posted: Wed Dec 07, 2016 6:53 pm Post subject: |
Yay !!
Moped mayhem on the cards?
Get in there Mr H ... can't wait to see 80mph out of your buzz bomb  _________________ We are where we are... |
fazey Show Star !
Posted: Fri Dec 09, 2016 12:04 pm Post subject: |
Nice find howie  |
Posted: Wed Apr 05, 2017 4:26 pm Post subject: |
It's running, a bit smokey, premix & auto so lots of oil on the garage floor
Just need new tyres, brake shoes, a number plate & a few bulbs then we're off to the mot station. |
Posted: Wed Apr 05, 2017 6:24 pm Post subject: |
Hi Howie,
she's alive! _________________ Kindest regards
Posted: Wed Apr 05, 2017 7:07 pm Post subject: |
Yes she is sir
I'll post a couple more up to date pics soon. Done some painting you see  |
Posted: Wed Apr 05, 2017 7:59 pm Post subject: |
Hi Howie,
looking forward to seeing the results. _________________ Kindest regards
Posted: Thu Apr 06, 2017 3:05 pm Post subject: |
Just from the picture fine sir, it both smells and sounds fantastic  _________________ We are where we are... |
Posted: Thu Apr 06, 2017 4:53 pm Post subject: |
It's got no wadding on the baffle at the moment so it sounds a bit rorty.
It has Castrol power 1 in the 2t tank & I think Motul 2t oil premixed with the fuel, smells a bit strange
The finest rattle can paint job (no expense spared). Just need a go faster stripe along the tank to hide the join between the red & white & this was the only angle I could find where you can't quite make out the filler & dents I missed
Ooh & I also need a pair of Kawasaki stickers, just to set it off.
Posted: Thu Apr 06, 2017 10:26 pm Post subject: |
Definitely look faster with a mighty Kawasaki sticker...
Loving it MR H  _________________ We are where we are... |
Posted: Fri Apr 07, 2017 8:52 am Post subject: |
Great stuff Howie.  |
Posted: Sat May 06, 2017 8:07 pm Post subject: |
Apparently, allegedly & according to my suppliers........ the speedo cable for my kc100 has 11mm fitments either end.
This isn't true, if you want a speedo cable for a kc100, look for a Honda h100 speedo. 11mm speedo end, 10mm wheel end.
Anyway, having fitted the bloody thing I took it out for a test run.
60mph! Now assuming the speedo is say 10% off, I'm happy with that. What I can't understand is I used all the same parts, from the same parts supplier to rebuild the engine on this one as I did the last one I built in a previous thread (which managed about 55mph if I remember correctly), so is it just down to speedo calibration?
There is no porting on this engine, nor was there any on the other. And carb is original as before.
Any ideas? |
Posted: Sat May 06, 2017 9:35 pm Post subject: |
I've had bikes (And cars...) that should be exactly the same but for some reason one was faster than the other? With ARs the casting of the barrel can vary significantly especially on the transfer inlets from the casing making a difference..
On the KC I wouldn't know ..
Surely its not something realky simple like you have a larger front / smaller rear sprocket? Presume the same spannies?  _________________ We are where we are... |
