kevin forster
Posted: Wed Aug 09, 2017 7:37 am Post subject: sdr200 fuel tap. |
Im trying to find a fuel tap for my sdr. Im assuming its found on another yamaha bike. Any advice on a replacement would be welcome. Or if by any chance somebodys got a spare i could buy.
Thanks
Kevin |
Joined: 31 Mar 2013 Posts: 185 Location: Sydney, Australia
Posted: Tue Aug 15, 2017 5:52 am Post subject: |
Kevin,
The fuel tap (51Y-24500-01) is still available from Yamaha, but isn't cheap (price 10390 Yen in Japan). It was originally an SRX250 part, but was fitted to some other models too (can't remember which ones off the top of my head).
You may like to consider changing to a "normal" on-off-reserve tap (i.e. not vacuum operated), which I covered in my project report (http://diffrentstrokers.com/phpBB2/viewtopic.php?t=2308). Unfortunately, the photos have disappeared, thanks to Photobucket . However, I have written some info in the text which may be of use to you if you want to choose the non-vacuum option. You will likely have to make an adaptor for such a tap, but that is easy enough to do using hand tools.
kevin forster
Posted: Wed Aug 16, 2017 10:30 am Post subject: |
Thanks for the reply. Great thread will help out alot. The fuel tap looks similar to the 3ma fuel tap |
