marky boy
Posted: Sun Feb 04, 2018 6:49 pm Post subject: sdr200 oil pump |
any one know what the gap between pulley andjuster plate on the
oil pump should be.
thanks |
Posted: Wed Feb 07, 2018 7:23 pm Post subject: |
| Sorry no! but if you search online i'm sure ive seen it on an owners manual, it's in Japanese but i think it has pictures |
marky boy
Posted: Wed Feb 07, 2018 8:59 pm Post subject: post subject |
yah cheers fella sort of . me no speaky engrish
but get the jist I know how to check gap wondered what it is . time for more digging |
Joined: 31 Mar 2013 Posts: 193 Location: Sydney, Australia
Posted: Sat Feb 17, 2018 12:16 am Post subject: |
The workshop manual says to remove the spark plug, slowly operate the kickstart lever, then measure the clearance between the adjuster pulley and the adjustment plate with a feeler gauge. Do this two or three times - the maximum gap obtained from these two or three measurements will be the existing minimum stroke. The specified minimum stroke is 0.15-0.20mm, so the existing shim can be replaced by one of different thickness if the existing minimum stroke is not within the range specified (Shim Part No.137-13137-00, various sizes).
There is a warning that after any adjustment, the lock nut should be tightened securely and the measurement made again to confirm the minimum stroke is within specification.
This is not something I worry about - my SDR hasn't got the oil pump! However, I hope the above info eliminates any confusion surrounding the measurement and the specification .
