Dixiesatellite
Posted: Mon Jun 18, 2018 1:15 pm Post subject: RG250 Gamma Engine Dimensions |
Hi,
Here in Japan there are always loads of Gammas being sold or parted out, so I wanted to transplant a Gamma engine into a different frame. In order to decide if a Gamma engine will fit, can anyone tell me the following dimensions?
1/ Width of the crankcase mounting points (to see how it matches up to the frame for adapters).
2/ Width of installed exhaust pipes where they exit the heads (to see if there is enough clearance on the other frame.
Thanks very much for your help.
Cheers,
Ian |
Dixiesatellite
Posted: Sun Jun 24, 2018 1:10 am Post subject: RG250 Gamma Engine Dimensions |
Would anyone be able to tell me the dimensions of frame clearance when pipes are installed? I don't have a n RG250 here I can check at the moment. Just looking for how wide the L & R pipes are in this location where they exit the heads to see if this will work in the other frame. Thanks very much for your help.
Ian |
how69
Posted: Sun Jun 24, 2018 10:24 am Post subject: |
Hi sorry for being a bit slow giving you info
the length is 14.5 inches
width is 14.5 inches
the height is around about 10 inches as I dont have the barrels on so am gauging the height the studs are still in so a bit a bove that would be around 10 inch.
hope this is good enough for you. _________________ We will get there in the end |
how69
Posted: Sun Jun 24, 2018 7:07 pm Post subject: |
Sorry about giving you useless
Info don’t know what I was reading
But not what you wanted.
The frame gap is 210mm wide
I have not got the pipes on so cannot give dim of
Those.
click on picture for larger image _________________ We will get there in the end |
Dixiesatellite
Posted: Sun Jun 24, 2018 10:21 pm Post subject: |
| how69 wrote: |
Those.
click on picture for larger image |
Hi, that's great - thank you very much indeed for taking these measurements - it is a great help
Cheers,
Ian |
