Joined: 31 Mar 2013 Posts: 184 Location: Sydney, Australia
Posted: Sat Sep 22, 2018 8:56 am Post subject: |
Frank,
I think (from memory) I made my own marks on the flywheel and a small dot punch on the side cover gasket face.
I put the dot punch mark in an arbitrary place on the gasket face close to the flywheel periphery where I could easily see it, then (with the cylinder head off), I used a dial gauge to mark the flywheel for TDC and a couple of suitable points on the ignition curve.
With the engine running, it was possible (using a strobe light) to see the ignition timing varying with engine speed.
