AR125 OIL LEAK
SmokerMatt
PostPosted: Tue Aug 17, 2021 3:04 am    Post subject: AR125 OIL LEAK Reply with quote
Hi,
I'm after some advice regarding a two stroke oil leak I found on my ar, the leak is coming from between the valve cover and the engine case, I'm in the process of ordering the special removal tool for the stator , once this has been removed from what I understand there is an 0-ring in situ, could this be the cause of the leak or could it be caused by a crank seal ?
Also if I removed the stator would I need to reset the ignition timing ?
Any advice would be great !
PostPosted: Fri Sep 03, 2021 10:59 am    Post subject: Reply with quote
Hello.
It's very unusual to get a 2 stroke oil leak in that location and suggests the large O ring between the RRIS casing and engine is not sealed.
Does the engine run? Have you noticed an air leak in the same place?
Have you got got 2 stroke in your gearbox? Is it leaking into the generator cover?
You can remove the flywheel with a air socket easily without the flywheel holding tool but worth having one anyway just get an adjustable one.
Stator can be removed and refitted without concern over timing. Im presuming its the later version with a pick up?
The screws holding the Stator and rris casing can be a pain if stuck. Take your time with these.
Let us know how you get on. Happy to help Very Happy
SmokerMatt
PostPosted: Sat Sep 04, 2021 2:34 am    Post subject: Reply with quote
Cheers for the reply
Regarding the oil, I'm presuming it's two stroke ? I use Nano Tech 4+ for the gearbox and RS 959 for the two stroke , they are both blue in colour so it's hard to work out what oil it is, I guess it could be gearbox oil coming through the crank seal but the engine is running sweet no problems at all
Regarding the two stroke in the gearbox, no
I did have a small amount of oil in the generator cover though, and yes it's later version with the pick up
I will sent an update once I have the Stator off, thanks for the advice about the air socket !
SmokerMatt
PostPosted: Tue Oct 19, 2021 11:55 pm    Post subject: Reply with quote
Well, you were right Top-shaggy it was the large O-ring that was causing the leak, on inspection it was almost completely flat so no wonder it was leaking though the case, I'm not really surprised it lost it's shape after 32 years though
I also changed the crank seal while I had everything apart
The hardest part was using the flywheel removal tool, it just would not come off I had to use a hammer on the T-bar to remove it , the main nut was actually easy to remove with the flywheel holder.
Thanks for the advice !
PostPosted: Fri Oct 22, 2021 12:23 am    Post subject: Reply with quote
Yay!
Pleased you got it sorted out. Brilliant
The flywheel can stick after many years, sometimes jammed on the woodruff key.
I'm glad you got flywheel off without damaging the magnets... got the tshirt in the past knocking the flywheel loose but damaged the magnets... lesson learned
Hope it's running well now
Top stuff Thumbs Up
