Posted: Sun Mar 29, 2009 5:03 pm Post subject: How do I test my CDI Unit? / RG250 Mklll Wiring Diagram |
Hope someone can help me out here. My longterm project RG250 has reached the point where it should run....and it did, twice for about a second each time!! Now I have no spark?!! The CDi unit is the suspect at the mo, as I cant get a feed to the coil.
Now if I unplugg the CDi, I get what appears to be alternating current at both the Green wire and the Black/Red, nothing at the others. Now if I unplug the 3 Pin connector at the Power Valve (Chamber Control Motor) then I get 8 Volts at the Red/White to the CDi....confusing...
Any help would be appreciated!! _________________ Breathing new life into an old Gamma!
