Posted: Sun Sep 27, 2009 3:27 pm Post subject: 250 250 Mk4 parts |
Hello,
Just recieved a partscatalogue for the RG 250 MK4.
Found out that the rear wheel with axle that i bought is not complete.
I need the r/h spacer and the bracket for the caliper.
They are not the same as the ones used on the Mk3.
64740-34A01 spacer
69721-34A00 bracket
Maybe someone have a spare??
Or does anyone know wich model is the 34A00??
Thanks very much.
Also the front fender for the Mk4 is a RG500 one....
Regards Erik |
walter
Posted: Wed Oct 28, 2009 11:03 pm Post subject: |
| Hi Erik, do you still need these parts? My Mk 4 is in the final stages of strip down and I'm rebuilding it as a Mk 3. Let me know if you need any Mk 4 specific parts. |
walter
Posted: Thu Oct 29, 2009 1:09 pm Post subject: |
| This Mk 4 is turning me into Victor Meldrew. Latest in the 'I don't believe it' category is the magneto stator. I noticed that the connectors from stator to loom are different on the Mk 4, it appears to be down to a decision to re-route the neutral switch wire. On the Mk 3 the wire is connected to the inside of the switch and is then bundled with all the other stator wires and connects to the loom adjacent to the stator plug. The Mk 4 just has to be different, the neutral wire is on the outside of the switch (on the outside of the crank case) and connects to a wire bundled with the sidestand cut out wires. This runs up the frame and plugs in to the loom near the front of the petrol tank. |
Posted: Thu Oct 29, 2009 7:19 pm Post subject: |
Goodevening Walter,
Y E S
please.............
I realy need the spacer and rear caliper bracket for the Mk4
I have send you a PM with my email.
Let me know what you want me to do.
Thanks very much
Erik |
Posted: Sat Jan 30, 2010 11:01 am Post subject: |
I made a list of major engine differences between the MK3 and MK4
11210-40A10-OFO cilinder
11220-40A10-OF0 cilinder
13150-40A10 reed valve assy
11269-20A03 pully controller
11301-40811 crankcase assy
11350-40811 cover magneto
12200-40A10 crank assy
13201-40A20 carb left
13202-40A20 carb right
13700-40A10 air claener assy
14310-40A10 muffler 1st rh
14340-40A10 muffler 1st lh
14301-40A20 muffler 2nd rh
14304-40A20 muffler 2nd lh
17730-24A00 cap radiator
24131-40A10 drive shaft
27510-40A10 front sprocket
08331-31258 circlip
25600-40A10 lever assy gear shifting
32101-40A20 stator assy
32900-40A20 CDI unit
33410-40A00 coil assy ignition
All the best
Erik
PS Walter did you have time to sort out the rear wheel spacer and bracket? |
Posted: Fri Feb 05, 2010 1:09 pm Post subject: |
Erik! That must have take hours to find the differences! Well done, who would have thought there were so many changes? _________________ Breathing new life into an old Gamma!
geoffrg
Posted: Thu Apr 29, 2010 2:06 pm Post subject: |
| is there any difference in power between the mk3 and mk4 rg engines.? . i got a mk4 motor to put into a mk3 chasis but the wiring connectors are different , anyone know if it is a straight forward colour to colour or is it a bit more complicated than that , cheers lads |
Posted: Thu Apr 29, 2010 3:44 pm Post subject: |
Sorry dont know.
Dont think it will be much if there is any.....
I hava a mk4 partscatalogue if you need to know something i will take a look for you. |
