		| Paul8899
				|  Posted: Mon Nov 15, 2010 10:53 pm    Post subject: Cagiva Mito 350 YPVS Project |   |
				| Hi all, thought I'd put a few pictures up of my mito 350 project I'm ( slowly) building. It all started when I saw Dougs Yagiva and I thought that I'd have a go at making one like it.
 I decided that instead of buying a dead mito and changing the engine over I would try and build one from a bare frame up. After buying the frame I then bought an 08 r6 swingarm, 09 zx10r wheels / calipers / handlebars , 04 zx10r wheels/discs and a 31k ypvs engine.
 I had to modify the mounts so that the engine will clear the swingarm and I dropped the front mounts slightly so that it now clears the existing mounts on the frame.  I also had to make the rear mount of billet as the right hand L shaped mount hit the swingarm after 1in of wheel travel.
 I have made a set of yokes,engine /suspension mounts and I'm about 3/4s the way through the rear subframe.
 I've still got to get a few bits to do on the chassis ( welding ) then hopefully its just a few little jobs left , the main one is make a sprocket carrier and sort the chain run. Then I can start rebuilding the engine.
 Here's a few pictures of some of the bits I've made
 Shock and rear subframe mounts
 Engine mounts
 Yokes
 Lightly modified r6 Swingarm ( got to weld some plates back in )
 An heres what the bike looks like in a rough build
 I'm hoping to get the bike finished by may 2011 but this might be subject to change
		| si.likes.guiness Show Star !
				|  Posted: Tue Nov 16, 2010 2:34 pm    Post subject: |   |
				| we do meet in the stangest places paul  bikes looking good mate |  |
		| Paul8899
				|  Posted: Tue Nov 16, 2010 7:49 pm    Post subject: |   |
	  | si.likes.guiness wrote: |
 we'll have to be careful otherwise people will talk
 The bikes getting there, just taking ages
 hows yours ?
				|  Posted: Tue Nov 16, 2010 10:34 pm    Post subject: |   |
				|  you cant rush these things though mate,their worth the extra time  i'm just waiting for the crank to arrive back at dans,then the engines back together  still quite a few things to do to it though  |  |
