geoffrg
Posted: Wed Jan 25, 2012 5:25 pm Post subject: my rg and a recently rescued 1982 x7 |
Posted: Wed Jan 25, 2012 6:07 pm Post subject: |
I really enjoy the challenge of a bike rebuild - but (and it's a big but on this one...) that X7 would be one step too far for me  _________________ We are where we are... |
geoffrg
Posted: Wed Mar 14, 2012 12:54 am Post subject: mk 1 rg forks |
| when i got this rg it had mk3 forks on it i think ,anyway i bought a set of mk1 forks of ebay last week went to fit them tonight and the front axle is to thick , does this mean i have a mk3 wheel aswell , is there a difference in axle sizes ? many thanks guys |
Posted: Wed Mar 14, 2012 5:38 am Post subject: |
Yes could be
This is for the RG 250 models
MK1 bearing 6301
MK2 bearing 6302 (german market version with 2 discs)
MK3 bearing 6301
The German MK2 model has a different front axle partnumber
Hope this helps
Erik |
geoffrg
Posted: Fri Mar 15, 2013 12:38 am Post subject: forks and brakes |
| still hane,nt got the forks sorted but the calipers dont line up with the mountings on the fork legs , any ideas what the cld be off they look like rg calipers , will try and post pics guys any ideas ? |
Posted: Fri Mar 15, 2013 5:47 am Post subject: |
Got myself a RG 250 MK2
found out that the front axle is bigger on this model.
also the front wheel is different
you can't put the wheelbearings in for the MK1 or Mk3 models.
So you have a MK3 front wheel i think
but it should fit the axle diameter on the MK1 fork (same wheelbearings)
only the discs are different on the MK3 there are 5 bolts and on the MK1 6 for each disc
The calipers for the MK1 model (2 piston version) will only fit the MK1 fork
the mounting holes are different
The calipers for the MK2 and MK3 are the same (four piston version) and won't fit the MK1 fork
hope this helps
Erik |
geoffrg
Posted: Sun Mar 17, 2013 2:26 am Post subject: |
will check it out tmw and see if i can figure it lol , thanks erik ur a true legend ,  |
geoffrg
Posted: Mon Mar 18, 2013 11:30 pm Post subject: |
| hi erik , i have a mk3 front wheel 5 bolt disc,s and 4 piston cailpers thanks again for the info mate |
