Fork oil
firebladeaid
PostPosted: Sat Oct 20, 2012 5:01 pm    Post subject: Fork oil Reply with quote
Anyone have any idea of capacity for my 3MA
it has 41mm dia forks
was considering 15w at 400 -450cc
what you think?
Bikes are for real people
yanw
PostPosted: Sat Oct 20, 2012 8:00 pm    Post subject: Reply with quote
The USD forks (3ma4-5) are 326ml 10W 190mm from top of collapsed leg (329ml 10w 180mm for the SP) http://www.pure-2-stroke-spirit.info/download/3MA/3MA3-4-5_workshop_manual_jp.pdf (section 5.1)
The conventional forks on the 3ma1 are 425ml 5w 150mm from the top of the leg http://www.pure-2-stroke-spirit.info/download/3MA/3MA1_workshop_manual_jp.pdf (section 7.23)
If you are a Japanese "Rocket boy on track" then 5w/10w oil is probably OK. If you are a fat European then 15w or 20w might see you bottoming out less.
TZR manuals and ting: http://www.pure-2-stroke-spirit.info/ They have spring length limits etc as well.
TZR forum (unless you are watching this on Dave then they will have probably moved shop again) http://www.pure2strokespirit.net/forums/
PostPosted: Sat Oct 20, 2012 11:42 pm    Post subject: Reply with quote
Laughing Laughing Laughing
Well that has dispelled all the myths of suspension set up for me, first class yanw, thank you Laughing
firebladeaid
PostPosted: Thu Oct 25, 2012 5:32 pm    Post subject: Reply with quote
Thanks for that Yanw.......... bit in the middle 15st but 1min 48 round cadwell full circuit Smile
