JC34
Posted: Tue Dec 11, 2012 11:23 am Post subject: RG250 oil pump connection |
Hi, i an working to restore a 250 RG 1987, at this time the oil pump is disconnected ( it run using mixing oil and gasoline inside the tank) , i want to reuse the oil pump to manage the mix. All is in place now , but i don't know whe i have to plug the 2 hoses coming from the oil pump ( in carb ? )
in red in the picture
Tanks to your help
best regards
JC34 - Suzuki 250 RG - France |
reggiebusa
Posted: Wed Dec 12, 2012 2:10 pm Post subject: |
They look like a clip that fits over the oil line to hold it on the carb. i'll check tonight when i get home. |
Posted: Fri Dec 14, 2012 5:51 am Post subject: |
The hoses should go on the cilinders
there should be on each cilinder a small brash tube
the hoses go on there and to make sure they stay on and the little clips should secure them
hope this helps
Erik |
JC34
Posted: Fri Dec 14, 2012 8:01 am Post subject: |
Thanks !
I don't find any plug on the 2 cylinders (or pipes) to connect the hoses, there is one litle on each carbs (interior and exterior) but i am not sure that it's the correct one. If some body can take a picture (or a draw) , sure it's help
best regards |
