rg250 with wider rims rgv or gsxr advice needed please ??
davethorn123
PostPosted: Wed Feb 13, 2013 1:20 pm    Post subject: rg250 with wider rims rgv or gsxr advice needed please ?? Reply with quote
Hi guys i want to fit a wider rear wheel to my mk2 rg250,ive seen it done before but it was a long time ago,
I think it should be a vj21 wheel but how to go about it??
Keep standard swingarm and spindle and make sleeves and spacers ??
Machine standard swingarm to accept vj21 spindle??
Use vj21 swingarm,spindle,shock etc??
Any advice would be greatly appreciated Very Happy
Thanks in advance
pedraine
PostPosted: Sat Mar 02, 2013 7:37 pm    Post subject: Reply with quote
hi,i have a gsx 600 f katana 88 rear whell in my moto.
i fit tire 130/70/17 with the standard swingarm and spindle...
View user's profile Send private message MSN Messenger
Norbo
PostPosted: Mon Mar 04, 2013 10:02 am    Post subject: Reply with quote
fitting wider wheels is a comon mod for many bikes . if your keeping the standard swinger then dont go up to big on the rear or things wont line uop . remember once you have fitted the rear wheel the front sprocket must line up with the front sprocket and the wider the rear the biger the ofset front you wil need.
The most comon way to do them is to masheen the sprocket carrier down and make a bush for the other side to fit them in. you will all so need to remove alloy from the caliper bracket as well on most bikes.
I have VJ21 running gear on my 31K ypvs they are not to wide and will fit in your G250 without to much trouble .
NKracing could do the job for you infact if you dont think you can do it .
www.rdlccrazy.co.uk. Home of The Onr Stop LC Shop
View user's profile Send private message Send e-mail Visit poster's website
