mito 350 ypvs
Goto page Previous  1, 2, 3
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Specials / Hybrids
dougon2wheels
PostPosted: Sun Sep 01, 2013 5:33 pm    Post subject: Reply with quote
oh yes,i enjoyed last year,hopefully they'll let me have the time off work Rolling Eyes
mikee
PostPosted: Thu Sep 05, 2013 8:49 pm    Post subject: Reply with quote
In that predicament at the moment
Anyway decided the mito I bought is going to be a 350
The weedy little 125 ain't doing it for me
Mike
dougon2wheels
PostPosted: Fri Sep 06, 2013 5:23 pm    Post subject: Reply with quote
Go for it mikee.....their great fun.....if you need any help Smile
mikee
PostPosted: Sat Sep 07, 2013 9:24 am    Post subject: Reply with quote
Wouldn't mind dimensions for the engine mounts
I see you've moved the motor from anand's original settings
I might buy a frame and do all the initial work before I drop the motor out of the mito , there's a couple on the bay at the moment
Got a k6 gixxer front end that will go in ,looks like the legs might even fit the mito yokes
Mike
dougon2wheels
PostPosted: Thu Sep 12, 2013 10:27 pm    Post subject: Reply with quote
sorry mikee,i have the drawings for the mounts ,but f@~# knows where,if i find them i'll let you have a set,the original mounts i made tended to make the bike squat under power,so i had a rethink,personally i think annads mounts make the chain run a little high,but i've never ridden one with those mounts,so i won't jugde.....
mikee
PostPosted: Thu Oct 17, 2013 8:30 am    Post subject: Reply with quote
started roughing out the mounts today
so will see if they fit tonight
been scouring the tinternet for ideas and variations on these , these a few
differing options on then
pics later , maybe
mike
mikee
PostPosted: Tue Jan 14, 2014 9:37 pm    Post subject: Reply with quote
So now the motors in
Tho I think I'm going to have to lift it a bit to give a bit more space for the rad
It's entered in the forthcoming 2stroke forum / practical sportsbike build off thing
Mike
dougon2wheels
PostPosted: Tue Jan 14, 2014 10:34 pm    Post subject: Reply with quote
looking good mikee,your right though,chop the bottom off the front frame mounts and move the bits you've chopped off into the gap and weld in,that'll raise the front of the engine and this will almost give you enough space to mount the rad.
mikee
PostPosted: Fri Jan 31, 2014 9:27 am    Post subject: Reply with quote
moved it up and back 10 mm
lifted the front mounts too
as you say almost enough space for the rad
plumbing next
mike
photobucket seem to playing up
its copied a chunk of my pics 3 times , then reckons ive used up my bandwidth allowance
arse
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Specials / Hybrids All times are GMT
Page 3 of 3
