scorchr6
Joined: 08 Jul 2011 Posts: 12 Location: kildare ireland
Posted: Fri Jul 08, 2011 4:44 pm Post subject: rg 250 gamma 87 whats it worth mint ? |
| mine is nearly mint and affraid to spend too much |
Posted: Sat Jul 09, 2011 5:33 am Post subject: |
What do you call mint??
100% original in original colors with no damage to the fairing.
Then it could raise some good money.
The fairing parts are very difficult to find new.
Most off the used parts are cracked.
The fairing brackets are allmost allways bent.
And no longer available new.
I bought several used sets but all bent......
Found a new one after searching for years.
If you are going to restore one.
Just do it because you like the model
You won't see your money back........
I have been working on a couple of RG 250's for some years now.
It has cost me a big fortune on genuine parts.
And still not ready.
Had to get a lot of parts from Japan and thats not cheap eather
But i love the RG's and i think its the best rideable 250 cc two stroke Suzuki ever made.
Erik |
scorchr6
Posted: Mon Jul 18, 2011 10:14 pm Post subject: |
hi eric , i have started putting bike back together
going to partially restore it , all steel work is straight just where the indicator on one side was a bit bent down so careful adjustment got it back , had the steel carefully shot blasted and asked for paint but got plastic coated instead ,wont be going back there in a hurry
pipes also got blasted , clean no dents just a few small pit marks , cans in good alu but some rust under and its spot weld attatched(any suggestions )??
the bike runs bit not driven yet , the brakes are sticking and pads are well past safe
39k on the clock , looked in at the pistons and barrels and they look good with little brown or scratching on pistons and bores look fine
have an rd 350 f2 ypvs i can purchase for 1000 euro but is that a hard transplant ?
i intend riding it and using 250 for a while and if i like the bike i might ypvs it , i had a 88 f2 350 about 10 years ago good power but it spat me off in a tank slapper , my last 2 stroke
so i need a stroker , back to my childhood  |
scorchr6
Posted: Sat Jul 23, 2011 5:48 pm Post subject: |
| just got a track rg and a shed of bits , good complete front end spare wheels , a good straight headlamp bracket and mk 4 complete front end on track bike bigger discs ect , 2 brand new micron ss pipes and cans , brand new 17 18 tires on the bike , also have rear 17 wheel complete , well happy here , all the bits to make a stunning bike |
Posted: Sat Jul 30, 2011 7:47 am Post subject: |
| scorchr6 wrote: |
Thats great
You hit the jackpot
Very rare find the MK4 running gear and you have it complete
No missing brackets etc.
The ss Microns are also perfect.
Never seen a set for sale
You can make a very nice RG with all the bits you have now.
The brakes on the MK4 front are a lot better than the MK3 ones.
And the MK3 ones are good
Could you post some pics?
Regards Erik |
scorchr6
Posted: Sat Jul 30, 2011 8:40 pm Post subject: |
[img]hi eric , front and im confused about , its got bigger forks in diameter bigger discs on 3 spoke wheels , also no gold adjuster on bottom of forks , top adjuster nut and no air valve , i have a matching 3 spoke 17 inch rear wheel , having no luck posting pics , how do i do it on this please ,
the end cans are micron power and ex chambers ase chrome or ss not sure , very light ,
got first spin on the bike yesterday , lovelyride in most ways , odd riding position compared to modern race bikes , lucky im short or i would feel odd
need to re jet carbs and adjust the needles to match the pipes , should be fun , any advice on that ??
i have a 200# jets from the track bike so going to try themstandards came out 160# , the track bike ran not so nice , power valves in open position and the needles in the carbs were adjusted to leaner than standard which couldnt be right ,
regards michael ,[/img] |
Posted: Sun Jul 31, 2011 6:01 am Post subject: |
PM send
You are right about the front end.
bigger diameter no anti dive units bigger discs and no air valve.
I have a MK 4 parts catalogue
If you need any numbers or need to know the different ones from the MK3 let me know
Its in Japanese though......
Erik |
