Tzr 250 3ma reverse cylinder help needed
Gadgeroonie
PostPosted: Fri Feb 10, 2012 5:09 pm    Post subject: Tzr 250 3ma reverse cylinder help needed Reply with quote
Hi Guys - i am new to the forum
have owned a reverse cylinder 250 for many many years
want to get it mot'd so i can get some use out of it this summer
the rear brake master cylinder appears to have perished rubbers and i need to replace / repair it
does anyone know what other yamaha's use the cylinder - i doubt it is unique to the 3ma
loving the web site and the oddball bikes on here !
Edd
PostPosted: Mon Mar 05, 2012 8:57 am    Post subject: Reply with quote
Hi;
You will need to buy oem parts to repair the caliper, they are quite expensive. Never seen after market brake kits but that doesnt mean it doesnt excist. Think e-bay will be the answer or yambits in the uk. Dont know what other bikes use the same calipers but my guess is it will be tdr and tzr models.
Edd
Gadgeroonie
PostPosted: Mon Mar 05, 2012 4:07 pm    Post subject: Reply with quote
Hi Ed,
cheers for the reply
I tried yambits but they had nothing
has anyone got any pics up close of the 2ma rear master cylinder / TDR etc
hoping i can use something off a different model
PostPosted: Mon Mar 05, 2012 4:32 pm    Post subject: Reply with quote
You can get the part-numbers off Pure 2-stroke Spirit.
Looks like '47X-W0042-50' covers the rear m/cyl kit, but you'd better check. Think that model code is RD500LC ?
Give Webbs of Lincoln or Fowlers of Bristol a call - both are recommended, you can even get a discount if you tell 'em you're on the TZR/TDR/RD forums. Wink
Or try CMSNL - they list it as in stock but you have to take that with a pinch of salt. Their site is useful for cross-checking part-numbers and looking at exploded parts diagrams too.
Gadgeroonie
PostPosted: Mon Mar 05, 2012 5:08 pm    Post subject: Reply with quote
Thanks Stroker boy
very much appreciated (y) Razz
Gadgeroonie
PostPosted: Mon Mar 05, 2012 5:25 pm    Post subject: Reply with quote
the part number was 3ma-2583-v00
ouch - 170 euros
must be 3ma only part
http://www.cmsnl.com/products/rr-master-cylinder_3ma2583v00/
PostPosted: Mon Mar 05, 2012 10:16 pm    Post subject: Reply with quote
If you need the whole m/cyl, you might be better off just trying something off another model, from ebay, a breaker or an autojumble.
louis
PostPosted: Tue Mar 06, 2012 6:26 pm    Post subject: Reply with quote
Hello Gadgeroonie,
A good option/upgrade is to use the rear brake from a tzr125 4dl
Is a brembo and the whole right step will bold on your 3ma with no problems.
And it work's great. Very Happy
Example:
http://www.ebay.de/itm/Yamaha-TZR-125-4DL-Belgarda-SP-Fusraste-Bremse-rechts-Bremshebel-Tragerplatte-/170712736693?pt=Motorrad_Kraftradteile&hash=item27bf45a3b5
with:
http://www.ebay.de/itm/YAMAHA-TZR125-4DL-BREMSE-FUSS-BREMSPUMPE-TZR-125-436-/310367096006?pt=Motorrad_Kraftradteile&hash=item4843520cc6
