turbod202
Posted: Tue Mar 27, 2012 9:13 pm Post subject: TZR 250 3XV power valves |
Hi all
Just finishing off a complete rebuild, of my '93 rs, but have run into a problem with the power valves.
Can someone please let me know if the power valve should be open or closed once it goes thorugh the cleaning cycle?
When i switch the igintion on, the power valves go thorugh the cleaning cycle and the power values are in the open position, is this the correct position?
Cheers in advance. |
maccas
Joined: 27 Oct 2010 Posts: 110 Location: Bristol and Hull
Posted: Wed Mar 28, 2012 8:25 am Post subject: |
Hi mate,
Yes it is, when you start the engine they will move round into the closed position.
Maccas |
ybk
Posted: Fri Mar 30, 2012 5:33 am Post subject: |
Make sure you align the slot on the PV pulley to the hole on the cylinder after they've done their cleaning cycle  |
