3xv Dogbones
Crank
PostPosted: Sun Mar 11, 2012 2:47 pm    Post subject: 3xv Dogbones Reply with quote
Hope somebody has an answer for this. where the bottom dogbone connects to the frame there seems to be 2 sets of mounting holes. One towards the motor and a set further back closer to the back wheel. If I connect to the set closer to the wheel will it increase the ride height?
ybk
PostPosted: Mon Mar 12, 2012 6:24 am    Post subject: Reply with quote
I vaguely recall someone from the old forum used the other mounting hole and found that it actually lowered ride height.. Confused
Crank
PostPosted: Mon Mar 12, 2012 7:59 pm    Post subject: Reply with quote
Thanks for the reply, was thinking along the same lines, just wanted an opinion. Will give it a go this weekend though!
