Crank
Posted: Wed Mar 14, 2012 6:31 am Post subject: 3XV Crank Rebuilding |
Right Gents
I ask this with trepidation, exactly what is the story with the 3XV crank, I recall from the tzr site and here that there is a problem rebuilding if a journal is damaged, mostly when a bearing has failed, now, can new bearings be installed, the bike is still running, but has developed a weird vibration, although it does come and go and is not constant I would rather take preventative steps. After reading a few other threads and the trouble and expense finding replacement cranks I would rather rip it out now and overhaul if possible. I suspect I need new crank seals anyway.
Info would be much appreciated!
Thanks |
Crank
Posted: Wed Mar 14, 2012 5:19 pm Post subject: |
c'mon guys! |
Edd
Posted: Thu Mar 15, 2012 4:42 am Post subject: |
Hi Crank;
I was able to rebuild a 3ma crank in SA the guys place is called cr3 engineering in Germiston. It did cost me R6000 and the crank is working fine. Unfortunately the 3xv I havent done yet but suspect a rebuild in about 3000km then she will hit 50 000 km. You dont need the oem ball bearings to do a rebuild with some research you can get away fairly cheap. I did my crank with oem parts. I would have saved R2000 if I bought bearings from a local suppier.
Have you phoned Yamaha to check if they still have the sub assembly's? You may be surprised.
Edd |
ybk
Posted: Thu Mar 15, 2012 5:39 am Post subject: |
I think the general consensus was that it can't be rebuilt, has to do with the journals being part of the webs? Wullie has also had an expensive failure with a rebuilt crank.. (think he had the journal sleeved or something)
Sorry to the bearer of bad news  |
Crank
Posted: Thu Mar 15, 2012 7:56 am Post subject: |
Thanks Edd, was it 6k with the bearings? |
Crank
Posted: Thu Mar 15, 2012 8:06 am Post subject: |
Just spoke to Roy at CR3, said he will have to take a look at the crank before he can tell me whats what. |
Edd
Posted: Fri Mar 16, 2012 10:58 am Post subject: |
Jip R6000 with oem bearings. |
Crank
Posted: Fri Mar 16, 2012 4:29 pm Post subject: |
Eish! |
