		| turbod202
				|  Posted: Tue Mar 27, 2012 9:13 pm    Post subject: TZR 250 3XV power valves |   |
				| Hi all
 Just finishing off a complete rebuild, of my '93 rs, but have run into a problem with the power valves.
 Can someone please let me know if the power valve should be open or closed once it goes thorugh the cleaning cycle?
 When i switch the igintion on, the power valves go thorugh the cleaning cycle and the power values are in the open position, is this the correct position?
 Cheers in advance.
		| maccas
				|  Posted: Wed Mar 28, 2012 8:25 am    Post subject: |   |
				| Hi mate,
 Yes it is, when you start the engine they will move round into the closed position.
 Maccas
		| ybk
				|  Posted: Fri Mar 30, 2012 5:33 am    Post subject: |   |
				| Make sure you align the slot on the PV pulley to the hole on the cylinder after they've done their cleaning cycle  |  |
