Honda MVX250F New Member!
Rich69
PostPosted: Sat May 05, 2012 8:50 pm    Post subject: Honda MVX250F New Member! Reply with quote
Hi everyone,
I have just recently purchased a couple of MVX250's which are not going, but am currently restoring to get back to their former glory.
Was given this site details from the seller, which is fantastic to see there are others who also enjoy this two stroke wonder from honda, however as you know parts are a nightmare to obtain! Sad
I have been searching the web for countless hours, I have found this site
http://www.diyspareparts.com/parts/honda/list/p/79/
which has some engine parts and have emailed them to see if they can freight to my Country-New Zealand.
I will put some pictures on soon of the bikes as soon as I can and of the progress also.
Rich
PostPosted: Sat May 05, 2012 11:35 pm    Post subject: Reply with quote
Welcome Rich
Ive never used the site you refer to for spares - let us know if they are reliable etc
hope all goes well with the build's
Thumbs Up
Mr FFF
PostPosted: Mon May 07, 2012 9:07 am    Post subject: MVX parts Reply with quote
This site is located in the UK which never got the MVX250 as an official bike. The UK only recieved them as Grey imports. DIY sells Honda machinery parts for Generators and mowers, so I doubt they will have MVX stock. You are right there are not many parts around and it will take some digging. Yahoo Japan is the best place but you will have to sign up to an auction deputy site to get them out of Japan.
I do have some stock of engine parts and would consider swaps for NOS if you find anything.
MVX250 1983 MVX250 1984 GT380J 1972
Valves are for toilets unless they are power valves.
Claim to fame. Have beeten Casey Stoner over a championship season.
Alastair
PostPosted: Fri May 11, 2012 8:43 pm    Post subject: Reply with quote
Econohonda, in your own country, claim to have the following for the MVX. Dave Silvers have some more as do CMSNL.
Part Number Description New or Used Quantity Model
061A0-KG4-T00 Gasket set new 1 KG4
08155-KG4-1006 new 11 KG4
08155-KG4-1007 new 10 KG4
08155-KG4-10A new 1 KG4
11391-KG4-000 GASKET new 1 KG4
11391-KG4-306 new 11 KG4
11393-KG4-000 new 6 KG4
11394-KG4-000 GASKET new 16 KG4
12191-KG4-000 12191KG4306 new 0 KG4
12191-KG4-306 Base gasket new 0 KG4
12391-KG4-000 O-RING new 11 KG4
13011-KG4-305 Ring set std. new 1 KG4
13012-KG4-305 Rings .25mm o/s new 2 KG4
13013-KG4-305 Rings .5 mm o/s new 10 KG4
13014-KG4-305 RING SET,(0.75) new 5 KG4
13091-KG4-305 Front piston .25mm o/s new 2 KG4
13091-KG4-505 Front piston .25mm o/s new 4 KG4
13096-KG4-305 Rear piston .25mm o/s new 1 KG4
13097-KG4-305 Rear piston .5mm o/s new 1 KG4
13101-KG4-505 Piston std. new 0 KG4
13103-KG4-000 new 5 KG4
13103-KG4-506 Rear piston new 4 KG4
13104-KG4-000 13104KG4505 new 4 KG4
13105-KG4-000 Piston std. new 0 KG4
13105-KG4-505 Piston std. new 0 KG4
13111-KG4-000 Piston pin new 10 KG4
13201-KG4-300 new 1 KG4
13202-KG4-300 New 4 KG4
13205-KG4-300 new 1 KG4
13381-KG4-300 new 1 KG4
14100-KG4-003 new 3 KG4
14132-KG4-000 new 59 KG4
15100-KG4-003 new 4 KG4
15312-KG4-000 new 1 KG4
15531-KG4-000 new 1 KG4
16010-KG4-003 GASKET SET new 1 KG4
16012-KG4-003 new 1 KG4
16013-KG4-003 new 1 KG4
16027-KG4-003 new 1 KG4
16231-KG4-000 new 21 KG4
16950-KG4-005 AUTO COCK,FUEL new 1 KG4
17211-KG4-000 new 1 KG4
17910-KG4-305 ZZDELETED new 1 KG4
18291-KG4-000 18291KG4405 new 5 KG4
18316-KG4-003 new 17 KG4
22100-KG4-000 new 1 KG4
22116-KG4-000 new 1 KG4
22401-KG4-000 new 5 KG4
22870-KG4-000 CABLE,CLUTCH new 1 KG4
24212-KG4-000 Selector fork new 1 KG4
24213-KG4-000 new 1 KG4
24701-KG4-000 PEDAL,GEAR CHANGE new 2 KG4
28261-KG4-000 NLA PC755695 new 4 KG4
30221-KG4-000 new 1 KG4
33400-KG4-000 new 2 KG4
33405-KG4-000 new 1 KG4
33450-KG4-010 new 1 KG4
35200-KG4-003 new 1 KG4
37103-KG4-008 new 2 KG4
37400-KG4-008 new 3 KG4
37402-KG4-008 new 1 KG4
41201-KG4-000 New 1 KG4
46500-KG4-000 new 1 KG4
50619-KG4-000 new 1 KG4
50630-KG4-000 new 2 KG4
52120-KG4-000 new 1 KG4
52170-KG4-000 new 2 KG4
53172-KG4-000 new 1 KG4
61104-KG4-000 new 1 KG4
61401-KG4-000 Cover* new 3 KG4
61402-KG4-000 new 1 KG4
64116-KG4-300ZA new 1 KG4
64117-KG4-300ZA new 3 KG4
77211-KG4-000 new 4 KG4
83641-KG4-000 Cowl set bolt* new 2 KG4
837A4-KG4-000ZA Left sidecover new 4 KG4
87121-KG4-300ZA new 1 KG4
87122-KG4-300ZA new 1 KG4
88110-KG4-650 Right mirror New 1 KG4
90004-KG4-000 Sump plug new 1 KG4
90121-KG4-000 new 1 KG4
90221-KG4-000 new 1 KG4
90380-KG4-000 new 11 KG4
91001-KG4-003 Bearing with hole new 1 KG4
91015-KG4-305 91015KG4000 new 2 KG4
91202-KG4-003 OIL SEAL,36X52X6 new 2 KG4
91203-KG4-003 OIL SEAL,32X52X8 new 3 KG4
91204-KG4-003 OIL SEAL,35X52X8 new 4 KG4
91303-KG4-000 O-RING new 3 KG4
Alastair
CBR1000RR6 (0 - Court in 2.5 seconds)
NS400RF
MTX80RFD
