MVX250 Re-build is under way
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda
Mr FFF
PostPosted: Sat Mar 05, 2011 7:59 pm    Post subject: MVX250 Re-build is under way Reply with quote
I've started the MVX250 re build today. loads of fun fitting the taper bearings and powder coated yokes to the powder coated frame.
New bearings fitted to the swing arm, so that will be fitted next
Just waiting for the engine to come back from being ceramic coated
MVX250 1983 MVX250 1984 GT380J 1972
Claim to fame. Have beeten Casey Stoner over a championship season.
PostPosted: Sat Mar 05, 2011 8:47 pm    Post subject: Reply with quote
I take it you are joking? Laughing
I love this part of a rebuild though, after all the dismantling, degreasing & prep to the frame ready for the powder coat, its gravy all the way.
Keep the pics coming fella
trev45
PostPosted: Sat Mar 05, 2011 10:31 pm    Post subject: Reply with quote
Great to see something different and if there are any bits you need let me know
Trev
Racing is for the track, riding is for the road
Both are FUN
Mr FFF
PostPosted: Sun Mar 13, 2011 11:00 pm    Post subject: Reply with quote
Todays efforts
Loom, tool and battery box, rear mudguard and light, both CDI boxes and powder coated grab rails
All fasteners have been re chromed, bright zinc or black zinc plated.
The black zinc is awesome on the case screws, kickstart etc. Pics to follow
next week should see the powder coated swing arm, shock and linkage
Trev45, still waiting for your call Smile
trev45
PostPosted: Mon Mar 14, 2011 8:24 pm    Post subject: Reply with quote
I will do it this weekend, I was waiting for the other bits but they wont be leaving Japan soon so I will back a list for you
Trev
Both are FUN
Mr FFF
PostPosted: Sun Mar 20, 2011 8:26 am    Post subject: Reply with quote
Yesterdays efforts. Spot the hidden mistake DOH !!!
Lesson learnt........study the pics pre stripdown before re-building
Mr FFF
PostPosted: Sat Apr 09, 2011 9:11 pm    Post subject: Reply with quote
Engine is now back from being ceramic coated. Just got to re-build it now
trev45
PostPosted: Sun Apr 10, 2011 3:50 am    Post subject: Reply with quote
looking good and sent a email today Embarassed sorry racing season started so busy
Trev
Both are FUN
Darin
PostPosted: Mon Apr 11, 2011 10:46 pm    Post subject: Reply with quote
Looking really good Ian and well on the way to being the best MVX on the planet probably! Cool
If I ever get round to tackling mine (don't hold your breath!!) I'll be on your case for tips!! Laughing
Bikes: www.diffrentstrokers.com
Trackdays: www.classicbiketrackdays.com
Cars: www.lancerregister.com
Mr FFF
PostPosted: Tue Apr 12, 2011 10:37 am    Post subject: A Set back Reply with quote
A bit of a set back. A big one in fact. Despite all thier assurances the company carrying out the re-finishing didn't follow the agreement and instructions to effectively mask everything, with the following results. These are the clutch operating arm bearings. With some luck, I do have these bearings in my parts box, and I'm off to see my engineer Dave Hammond on Saturday to use his skills and workshop to remove and replace them.
I'm gutted, not only because of the set back, but also as this delay will probably mean that I won't be finished by the end of this summer.
I will get there in the end
Just recieved £2K worth of more engine spares. Still looking to swap, deal with anyone on this forum
Darin
PostPosted: Tue Apr 12, 2011 10:56 pm    Post subject: Reply with quote
Yeah that's a bugger and a set back Ian, but hopefully the machine shop have done the right thing - or what they can. The bike will be done before you know it too! Smile
Mr FFF
PostPosted: Sat Apr 23, 2011 4:34 pm    Post subject: Reply with quote
Might not seem much, but I have got all my Fork and Brake parts back from ceramic coating, and 1 fork leg is now built with new bushes, seals etc and re chromed stanchions.
Massive relief after the problems they caused with the coating on my engine
Watch this space
Mr FFF
PostPosted: Mon May 30, 2011 10:13 am    Post subject: Engine Build Reply with quote
Great progress this weekend. I have got my cases back from Dave Hammond who has cleaned the insides and replaced the clutch operating arm bearings. Checked and cleaned the gear clusters and changed the input shaft bearing and assembled into case with new oil seal. Brand new crank fitted complete with new end seals and all bolted up. The Black Zinc case bolts look the nuts too. Well worth getting those plated.
Mr FFF
PostPosted: Thu Jun 09, 2011 6:53 pm    Post subject: More Progress Reply with quote
More progress this week.
Leasons learnt......read manual before starting work
Gear shift cover needs to be fitted with engine out of the frame........Doh
Mr FFF
PostPosted: Mon Jul 18, 2011 5:16 pm    Post subject: Rear Cylinder Reply with quote
last Pic was a dry run to make sure water and oil pipes fitted OK. I have a week off so its back out in the shed for a bit of therapy
New rear piston and rings fitted along with the cylinder.
I'm still looking for a front Std piston and a set of 0.25 rings. Anyone? I am prepared to swap in your favour. What do you need?
PS the 18mm piston pin is home made as no gen Honda available
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda All times are GMT
Page 1 of 3
