another yamagama
mikee
PostPosted: Tue Nov 06, 2012 6:40 pm    Post subject: another yamagama Reply with quote
dug this out from under the hedge belonged to a member on here , going to get it on the road next year ,i hope , going to be a (low) budget build from stuff i have lying about , luckily i have a good amount of stuff lying about
first thing i did was to try and fit some 4dl yokes , and they bolt on no bother
so last night i stripped it and cleaned all the hedge clippings out
and will get on cleaning the rest of the muck off
more pics to follow
mike
PostPosted: Tue Nov 06, 2012 6:56 pm    Post subject: Reply with quote
Great stuff Mike, looking forward to the build Cool
I have to say though ... When you state you have a good amount of stuff laying around? Does that include another complete donor bike?? Lol
Sounds like your garage is like mine Shocked Wave
mikee
PostPosted: Wed Nov 07, 2012 12:39 pm    Post subject: Reply with quote
tried the r6 shock in it last night ,its 10mm shorter and fits well into the swinging arm /full floater set up only need 2 shorter spacers on the bottom mount , but , the reservoir fouls the
back engine mount cross member , tried an fzr 600 shock in and that will go with a little bit of surgery ,its 25 mm longer tho so thats out unless i change the link bars
i'll go see my mate pete the breaker and see what he's got kicking about
there's always the standard shock if nowt turns up , needs a bit of work tho
got some engine plates and spacers made up too
will get the bolts done tonight maybe , tho might spend some time on the lc tonight
cinder
PostPosted: Wed Nov 07, 2012 5:58 pm    Post subject: Reply with quote
i used a mito shock on mine i had to alter the top mount but it works well.what motor are you using?
g king
mikee
PostPosted: Wed Nov 07, 2012 10:37 pm    Post subject: Reply with quote
i saw yours in ps and the lc club mag
remember it from a long time ago too
my mate pete the breaker's got a load of shocks to rake thru so might find something there
might fit a 31k that i have ,or a 4l0 , keep looking at tz barrels and stuff
on the bay tho Very Happy
mikee
PostPosted: Thu Nov 08, 2012 10:24 pm    Post subject: Reply with quote
got some swinging arm end plates made today and engine mount bolts sorted
next up digging out the other bits
cinder
PostPosted: Fri Nov 09, 2012 12:25 pm    Post subject: Reply with quote
what motor r u using,and what else r u planning
g king
mikee
PostPosted: Fri Nov 09, 2012 6:02 pm    Post subject: Reply with quote
still not sure about motors
like the simplicity of the 4lo motor and i have a couple that i could use
also have 2 valvie motors , will have to see what needs the least work and money spent
got my tank delivered today so will have a looka at that later on
maybe do some pics too
cheers for the pic cinder
mikee
PostPosted: Sat Nov 10, 2012 10:10 pm    Post subject: Reply with quote
Found another valvie motor and a further 2 lc engines along with a tzr 2 ma motor I forgot I had
So I'll have a look and see what's the healthiest and go with that
4l1/0 I think
Got wheels and some other bits dug out too
Mike
mikee
PostPosted: Sun Nov 11, 2012 6:05 pm    Post subject: Reply with quote
todays effort , 4dl wheels , need a cush drive tho ,anyone ?
found a fireblade shock that fits ,thinking about turning the dogbones into adjustable ones ,spacers to be made tomorrow
PostPosted: Sun Nov 11, 2012 6:20 pm    Post subject: Reply with quote
I bet it's mega handy having that massive old lathe laying around Smile
Number of times I've threatened to buy one when I see machine shops closing down.. Rolling Eyes
mikee
PostPosted: Sun Nov 11, 2012 8:16 pm    Post subject: Reply with quote
DO IT SHAG , you can get these things for a couple of hundred quid
just get as much tooling as possible whilst your at it
i have a benchtop mill too ,a sieg x3
and 2 home built cnc's a small mill and an engraver
the money i charge for machining your better buying your own over a few jobs Very Happy
mikee
PostPosted: Tue Nov 20, 2012 6:24 pm    Post subject: Reply with quote
Got the wheel spacers made up today ,as my sprocket carrier arrived yesterday ,so must get some tyres sorted out
Got a bracket to mount the tank made up and won a cheap tz seat on the bay
So will get that sized up when it arrives
Made some plates up to attach the vj22 footrest assemblies
The engine mounts have caused me a wee problem ,I made them to the dimensions in the magazine article , but the motor sits too low ,so made up shorter plates to lift the motor 2 mm at the rear
Try and get that fitted tonight
Mike
cinder
PostPosted: Wed Nov 21, 2012 9:15 pm    Post subject: Reply with quote
came across the same problem myself m8,i filed a half round in the original rear frame bracket to allow the rear bolt to be raised about 6mm if that helps
g king
mikee
PostPosted: Fri Nov 23, 2012 9:25 am    Post subject: Reply with quote
i hope it wont come to that , its already had a valvie motor in it and
is registered as such ,maybe just a tolerance stack up issue
anyway ,turns out both the wheels i fitted have a runout in them ,so
i dug a pair out i was saving for an lc build
only problem is that i now need yet another cush drive , i'm told (by yats)
that the standard tdr/ 2ma carrier is narrower than the 3ma/4dl one
so thats what i think i need now ,also looks as if i need to move the motor
toward the drive side a bit so holding back on re-mounting it ,offset sprocket is another solution
so now awaiting a tz seat i won cheap on the bay ,bet that dosent fit either Laughing
