Ar 50 80 head bearings
PostPosted: Sat Dec 29, 2012 11:20 am    Post subject: Ar 50 80 head bearings Reply with quote
Anyone any idea what sizes the head bearings are on an ar? And are the a different size top and bottom?
I measured a bearing i had left over but can be sure it was for the ar or that i was accurate enough measuring it or even that the bearing wasnt worn,
But you will be pleased to know this means the four year ar project is having its forks put back in the frame!
Then in another four years ill put the swing arm and wheels on! Laughing
PostPosted: Sat Dec 29, 2012 1:34 pm    Post subject: Reply with quote
Paul, see other thread for AR125 steering head bearings
I have checked the part numbers for the steering head bearings (top and bottom) against the AR50 model C6 and they are the same as for the AR125.
Of course I'm assuming that all the AR50/80 models are the same ( which is the case for the 125)
Hope that answers your question Wink
PostPosted: Sat Dec 29, 2012 7:01 pm    Post subject: Reply with quote
Thankyou ts your a star, the build can re commence alongside the gag!
PostPosted: Sat Dec 29, 2012 7:03 pm    Post subject: Reply with quote
