Posted: Sat Dec 29, 2012 1:16 pm Post subject: AR125 info on steering head bearings |
In responding to another post, I thought I would show the difference between top / bottom steering head bearings on the AR125 - OEM compared to aftermarket roller bearings.
The ones to the left are for the top of the steering stem and have an inner diameter of 25mm
The ones to the right are for the bottom and have an internal diameter of 28mm
Both sets (upper and lower) have an external diameter of 46.02mm (measured cold 10 degrees C)
Ball bearings for OEM cones not shown.
Posted: Sat Dec 29, 2012 7:09 pm Post subject: |
Hello again ts do you know the actual ball bearing diameter? Or am i just being far too picky now! They were pretty new races when i stripped it so really just want to replace the balls but i wanted to order them from a local bearing suplier rather than ebay,
If not ill just have to replace with rollers
Thanks _________________ Gagging for it |
Posted: Sat Dec 29, 2012 9:17 pm Post subject: |
Ball bearing diameter is: 3/16 inch or 4.7625mm
I went to the garage to measure them and realised the size was in the parts scan above...  _________________ We are where we are... |
Posted: Sun Dec 30, 2012 11:12 am Post subject: |
Thanks again, i should have zoomed in a read that really so sorry to have wasted your time! _________________ Gagging for it |
Posted: Sun Dec 30, 2012 12:58 pm Post subject: |
Yeah, fancy wasting my time ...ho ho ho
Not a problem fella, I'm more that happy to help
PS you can owe me a pint when I catch you at the Premier  _________________ We are where we are... |
