Xebastian
Joined: 04 Jan 2012 Posts: 4 Location: Argentina, Buenos Aires
Posted: Thu Apr 04, 2013 10:24 pm Post subject: [request] MVX250 rear piston pin information |
Someone have a 18mm rear piston pin in hand to measure the inner diameter and length?
I would very grateful for the data. |
Mr FFF
Joined: 04 Sep 2010 Posts: 88 Location: West Malling, Kent (Nr Brands)
Posted: Mon Apr 22, 2013 2:20 pm Post subject: MVX 18mm rear pin |
The dimensions are 39x18x8
however I am using an 18mm pin from a KTM250 single off road bike shortend to the 39mm although the centre is more than the Honda's 8mm it seems to make no difference. i also use the KTM small end brearing as its the same sixe as the Honda original
Hope that helps you out
ian _________________ MVX250 1983 MVX250 1984 GT380J 1972
Valves are for toilets unless they are power valves.
Claim to fame. Have beeten Casey Stoner over a championship season. |
