[request] MVX250 rear piston pin information
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda
Xebastian
PostPosted: Thu Apr 04, 2013 10:24 pm    Post subject: [request] MVX250 rear piston pin information Reply with quote
Someone have a 18mm rear piston pin in hand to measure the inner diameter and length?
I would very grateful for the data.
Mr FFF
PostPosted: Mon Apr 22, 2013 2:20 pm    Post subject: MVX 18mm rear pin Reply with quote
The dimensions are 39x18x8
however I am using an 18mm pin from a KTM250 single off road bike shortend to the 39mm although the centre is more than the Honda's 8mm it seems to make no difference. i also use the KTM small end brearing as its the same sixe as the Honda original
Hope that helps you out
Regards
ian
MVX250 1983 MVX250 1984 GT380J 1972
Claim to fame. Have beeten Casey Stoner over a championship season.
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda All times are GMT
