Check Over
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Four-strokes
PostPosted: Sun May 17, 2015 9:51 am    Post subject: Check Over Reply with quote
Thought I'd better check over the Buell before I go away on it in June.
Strip the front brake, clean the pads, pistons and disk. And bleed the master cylinder and calliper.
And the other side.... Hang on, there's only one disk, good thinking Eric.
Now, check and adjust the chain.
Well good thinking again Eric old boy, Nothing to do here.
Right, where do I put the coolant?
PostPosted: Sun May 17, 2015 5:46 pm    Post subject: Reply with quote
Always liked these, and you dont see too many about either which is nice
And a nice clean example you have there too
PostPosted: Sun May 17, 2015 11:46 pm    Post subject: Reply with quote
Lovely Cool
PostPosted: Mon May 25, 2015 11:48 am    Post subject: Reply with quote
There must be a spark plug or two in there somewhere...
PostPosted: Thu Jun 11, 2015 11:04 am    Post subject: Reply with quote
Four hundred and eighty miles on the Buell, never missed a beat. Fuel pump is getting noisy though, that might have to be my next job.
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Four-strokes All times are GMT
