RG 250 MK3 (newbie)
Abarthoso
PostPosted: Thu Mar 20, 2014 10:19 am    Post subject: RG 250 MK3 (newbie) Reply with quote
This is my fist post on the forum.
I'm trying to bring my RG to it's original glory.
This project started because a found a new engine! a suzuki dealer has kept it in a corner of the garage after having dismounted a new motorcycle for spare parts purposes.
It' was such an emotional moment when I found it!
By the way, the engine has been opened to take a gear (the second gear, if I good remember) and then closed and stored for 20+ years.
I found it, bought a used (misused...) gamma and began my project.
My buddy, who is also a suzuki mechanic, has checked and closed the engine carefully.
My problem now is that is vibrates a bit too much.
Since I do not have infos (I found them desperately on the net without success) I'd like to know from you guys if this behaviour is quite common with this particular model.
If not, where should I check in order to find the possible cause?
Thanks you for your help.
Thank-you[/url]
BRG1200
PostPosted: Thu Mar 20, 2014 12:10 pm    Post subject: Reply with quote
Surprised if it vibrates particularly.
Good find - a new 20 year old motor!
RZ250 rolling resto
RG250 '84 resto
RD350LC basket case
