RGBARGEY
Posted: Tue Aug 26, 2014 5:08 pm Post subject: gammaha |
Need help with following
Brakes
Forks
Guidelines
Help please anyone e who has built one |
Joined: 15 Nov 2006 Posts: 1295 Location: Oop North, UK
Posted: Wed Aug 27, 2014 9:17 am Post subject: |
Might need a few more details. Is a Gammaha the same as a YammaGamma, ie. an RG250 with an LC/YPVS motor ? Plenty of those been done before, a lot of 'em stick with standard Suzuki running gear. Later RGV transplants should be relatively straightforward too if you want an upgrade. Just fit the whole front-end rather than mess about making odd bits from different bikes fit together. Although Suzuki parts are more interchangeable than most.
You'll need to tell us what you're planning to build. "Gammaha" could be a Yamaha Passola with an RG500 motor...  |
gammaguy21
Posted: Thu Aug 28, 2014 12:56 pm Post subject: |
| I have a yammagamma, but like StrokerBoy says, we need more info to help. |
Posted: Sat Aug 30, 2014 9:29 pm Post subject: |
I want a yammagamma! _________________ Gagging for it |
nick69 Show Star !
Joined: 18 Jan 2007 Posts: 108 Location: Pontefract West Yorks
Posted: Sun Aug 31, 2014 12:17 pm Post subject: |
Pics please  |
RGBARGEY
Posted: Mon Sep 01, 2014 9:02 pm Post subject: Gammha |
Ok lets start again now im on a laptop not a tablet
yes i stand corrected I honestly thought from 1987 the PB article called it a gammha
think I have most things covered as follows
forks I now have decided to use the MK3 forks after reading the article in this months bike mag was worried the the clip ons under the yolk would clash with the MK2 fairing
NK for the spacers and plates
guidelines is meant to say fuel lines now ths has got me confused do you need to split after the tap
also I have nearly a full bike to sell will be posting in for sale soon
Thanks to all |
RGBARGEY
Posted: Mon Sep 01, 2014 9:07 pm Post subject: ??? |
| dont know why it has posted four times confused I am |
DSBBadmin Site Admin
Posted: Tue Sep 02, 2014 10:54 am Post subject: Re: ??? |
| RGBARGEY wrote: |
Fixed that for you.  |
gammaguy21
Posted: Tue Sep 02, 2014 2:29 pm Post subject: |
| nick69 wrote: |
Pics please  |
Who's? Mine?
Here's mine... mk3 gamma with '86 rz350 engine. Still lots to do, but having too much fun riding it as it is now.
Modifications waiting on the spare gamma
gammaguy21
Posted: Tue Sep 02, 2014 2:35 pm Post subject: Re: Gammha |
| RGBARGEY wrote: |
On mine, I split the fuel line after the tap to a "Y" to feed each carb equally. |
mikee
Posted: Fri Sep 05, 2014 3:05 pm Post subject: |
This is mine ,
Need to get it insured then on the road , was built from bits I had lying around
A tidy up bike
Y piece for the fuel hose , and your engine plates may not fit , I had to drastically mod the rear mount on mine
Mike |
RGBARGEY
Posted: Fri Sep 05, 2014 5:25 pm Post subject: Gammaha |
| Please enlighten me on the engine plates was yours from NK made to the dims given in the PB article has any one else had these probs fitting the engine the spare frame has had the mounts on the rear altered but the heathen who owned it at some time cut the back end of the frame off why do people butcher frames beyond sense and reason |
RGBARGEY
Posted: Fri Sep 05, 2014 5:29 pm Post subject: Pics |
To you all who have posted pics all the bikes look great cannot wait to get this built
What have you all done with the frames I don't know weather to polish / paint / or powder coat
Bodywork standard or Skoal bandit
Ideas and comments please |
mikee
Posted: Fri Sep 05, 2014 6:12 pm Post subject: |
I made my own plates to the magazine article sizes , 26mm pitch iirc
Ended up being near 13 mm when finished , and could still do with going 3-4 mm higher , however it's a mk1 frame with a 4l1 non tiebar motor , this aside I've never had issues fitting lc and pv motors in the opposing frames before
The other issue with the 4l motor is it's a real PITA to get the top end off
If your fitting a valvie motor you may not have these issues
Mike |
mikee
Posted: Fri Sep 05, 2014 6:18 pm Post subject: |
They probably cut the frame to run a seat like mine
Hacksawing still to be done
As for finish on the frame , I just left mine as is , it wasn't too bad , if I redo it I will probably get it powder coated in a similar colour to the anodised stock finish
Bodywork is up to you , mines going Marlborough white / flouro after the tz faring goes on
Mike |
