		| rlwc
		| Top-shaggy Show Star !
				|  Posted: Fri Oct 31, 2014 9:46 am    Post subject: |   |
				| Rust on the alloy frame ? I wish I could see the pictures...  _________________
		| gammaguy21
		| rlwc
				|  Posted: Fri Oct 31, 2014 1:00 pm    Post subject: |   |
				| Yes those are the pics of alloy frame of my bike. Thanks very much gammaguy21 for your help.
 "Together Polluting The Planet"
				|  Posted: Fri Oct 31, 2014 2:25 pm    Post subject: |   |
				| Corrosion and slight pitting of the alloy?
 I'm not familiar with that frame, is it alloy with a silver painted or anodised  type finish or just bare alloy?
 I know this sounds a bit Heath Robinson .. But have you tried a very mild cleaner like Mr Sheen on the pitting? Something like that to clean without polishing the alloy (not autosol)..
 If its coated or painted .. It may not be so easy to sort the pitting if its lifted the surface.
 I'm sure someone on here has rebuilt one of these bikes?..
		| rlwc
				|  Posted: Sat Nov 01, 2014 4:08 am    Post subject: |   |
				| I think it is anodised type finish of factory. I haven't tried Mr. Sheen yet but I use Autosol polish...it didn't work.
 Any information is much appreciated.
				|  Posted: Sat Nov 01, 2014 9:15 am    Post subject: |   |
				| If it's a factory anodised finish that's pitted then unless I'm mistaken the only solution (if you want oem look) is to strip the anodising by etching the aluminum in sodium hydroxide or similar acid or alkaline etch solutions. This gets you back to the base aluminium and from there it is re-anodised - which in itself is not really a DIY job as it's an electrochemical process. (Well I wouldn't tackle it - it would be frame off to the anodisers job..)
 I suppose you could strip the anodising and polish the frame ? Not sure it would be easy to get a good surface finish on visible parts of the frame but I've seen some amazing work by people gifted with a supply of emery and autosol (oh and no finger ends..lol)
 Other than that options? Paint / powder coat etc - but you knew that anyway
 Why not leave it as it is and enjoy the bike.
 For me, It's got maturity and a patina like a fine rare single malt or oak aged fine wine.. It's lovely
		| rlwc
				|  Posted: Sat Nov 01, 2014 2:43 pm    Post subject: |   |
				| Thanks mate...I'm thinking the same thing to re-adonised the frame. Use of emery won't scratch the surface? Yes it looks vintage and lovely
