AR-jack
Posted: Fri Oct 30, 2015 5:51 pm Post subject: nikkon exhaust |
anyone else running a nikkon whats your engine peak out at
im running a open disc. ported barrel , skimmed head. 24 carbs still, and nikkon exhaust but it peaks at 10,500rpm no more
just wondering cause i have read some where nikkons peak at 10/10,500rpm
i wondering if anyone else has this _________________ ar125 a1 1983, ar125 b2 1988, ar125 b4 1988, ar125 b7 1991, kinroad xt50q 2011
XD
jack |
fazey Show Star !
Posted: Fri Oct 30, 2015 7:37 pm Post subject: |
| I.have puchased a nickon exhaust but in the middle of a rebuild, will be in touch |
AR-jack
Posted: Fri Oct 30, 2015 7:44 pm Post subject: |
thanks _________________ ar125 a1 1983, ar125 b2 1988, ar125 b4 1988, ar125 b7 1991, kinroad xt50q 2011
XD
jack |
Posted: Sat Oct 31, 2015 12:21 am Post subject: |
I have a original Nikon and that peaked at 11000. So not much difference.
Thing is most of the aftermarket exhausts won't go much beyond what the standard engine was capable of as that's what they will have been based on.
The micron for example was designed for the B model and stinger length needs reducing slightly for A model to get most from it.
Is the bike pulling peak revs in top gear? As you may be better going for torque and better gearing?
I always remember a shoot out between the Honda MBX, AR125 and RD125LC in a 80s magazine, all unrestricted bikes. The AR and RD had 22hp, the MBX 18hp.... And yet the MBX was the fastest top speed simply because it pulled its gearing better. I have the mag somewhere .. _________________ We are where we are... |
AR-jack
Posted: Sat Oct 31, 2015 12:48 am Post subject: |
its just i was looking up ARs again and found it just i thought still it may just be the set up but it appears to be the exhaust _________________ ar125 a1 1983, ar125 b2 1988, ar125 b4 1988, ar125 b7 1991, kinroad xt50q 2011
XD
jack |
