fazey Show Star !
Posted: Fri Dec 04, 2015 11:14 am Post subject: engine bolt sizing chart ar125 |
For anyone wanting to change there engine screws to something thats easier to undo. nearly all of mine needed a impact driver or a centre punch to undo them and most where completely knackered.
Crankcase halfs 6 x m6 x 35mm
5 x m6 x 45mm
rotor housing 5 x m6 x 35mm
pick up 2 x m5 x 10mm
stator plate 3 x m5 x 30mm
stator cover 5 x m6 x 20mm
clutch cover 9 x m6 x 30mm
oil pump 1 x m5 x 25mm
oil pump bracket 1 x m6 x 10mm
water pump cover 2 x m6 x 35mm
2 x m6 x 70mm
oil pump cover 1 x m6 x 10mm
2 x m6 x 25mm
water pump hose 2 x m5 x 16mm
sprocket carrier 2 x m6 x 16mm
Feel free to add any other bolt sizes to the rest of the bike i.e. frame bolts, swinger bolts, wheel nuts and bolts. |
Posted: Sat Dec 05, 2015 12:24 am Post subject: |
Thanks Pete, that's really helpful especially the engine casings as I've never bothered to measure them and your right...an absolute Biatch to get out
Gauntlet drawn now on the other bolt sizings..  _________________ We are where we are... |
