AR125 Fuel Tank volume
PostPosted: Sun Nov 29, 2015 5:23 pm    Post subject: AR125 Fuel Tank volume Reply with quote
Question I was asked today, not so much the capacity that was the issue but the volume at reserve..
Took me a while to find this one so thought I would post it as an aide memoir .. Reserve info not in the Haynes Smile
Total AR125 fuel tank volume = 11.5 litres
Total remaining once the fuel tap hits reserve = 0.8 litres
When I fill one of mine up from totally empty I will record when the fuel light comes on and post that too. The fuel light gradually flickers and gets brighter as you approach the low fuel point. Once it gets really low the fuel light stays on. This happens before you hit reserve on the fuel tap.. But not by much so may be around 1litre remaining (TBC)
PostPosted: Mon Nov 30, 2015 11:19 am    Post subject: Reply with quote
That be just over 2 gallons then. Very Happy
