dougindoors
Joined: 30 May 2016 Posts: 24 Location: rochester kent
Posted: Sun Jun 05, 2016 3:14 pm Post subject: Clutch cable splitter |
Has any one else got a cable splitter on the clutch cable it's located on the left hand side mounted to the frame just under the tank, the unused cable comes out the back of the tank under the seat, has me fooled. _________________ Two Smokey and they bandit |
Posted: Sun Jun 05, 2016 6:47 pm Post subject: |
The spare cable from the splitter is for the side stand.
The early versions also had a switch on the side stand too. This was removed on the later versions B3 onwards but the cable was retained.
Aka: When you pull the clutch the side stand lifts itself into the safe riding position. _________________ We are where we are... |
dougindoors
Posted: Sun Jun 05, 2016 8:06 pm Post subject: Splitter |
Ah ha, I did suspect that, it was the only thing I could think it did, unless it controller the ejector seat for the pillion lol. By the way Shaun the left side panel has all its lugs so I have a patern, but thanks for your time and the photos. _________________ Two Smokey and they bandit |
